In a six cylinder engine like mine, when it is running and warmed up, in theory the galleries should be full, and there needs to be enough in the sump for the oil pump to operate.
How much oil do you think is on the walls, the other moving parts, and draining down from the heads? By volume?
I reckon maybe 1/3 of a quart.
Your thoughts?
Your thoughts?
