Originally Posted By: kschachn
There is no such thing as water saturated ethanol. Water is completely miscible in ethanol. Once again the only determining factor would be the concentration of alcohol in the gasoline. The guy keeps talking about alcohols being saturated with water which is meaningless.
Water could be saturated to the point where the ethanol content isn't enough that the blend of water/ethanol/gasoline is miscible.
Then there's phase separation. I've personally seen that in a lawn mower. I suppose that's more likely because the tank isn't sealed like a modern vehicle. I wasn't quite sure how to fix it either.
