http://www.blauparts.com/proddetail.asp?prod=F2A1007-A
It turns out the Audi's ATF fluid is a "lifetime" fluid. I dont like the sound of that. Blauparts.com has ATF drain and fill kits for 96-06 Audi A4's. With the fluid, instructions, fasteners/ hardware, filter and fluid extracting pump, the kit is about $120. It looks like the ATF has to meet Volkwagen's TL52162 spec. Turns out Maxlife ATF meets this spec.
Apparently the VW fluid is yellow while Maxlife is red.. This was mentioned on a forum, but I cant see mixing the two causing any issue. Is there any reason to not simply run Maxlife ATF in this old girl?
Thanks BITOG.
Thanks BITOG.
