It looks this formula is almost impossible to find on the Internet. I am posting it here in case someone needs it to estimate belt tension without using a tension gauge. The idea is to apply perpendicular pressure on the belt midway between two pulleys and measure the deflection. Your index finger applies about 10 lb of pressure when you push with it but you should first "calibrate" your index finger using some kind of weight scale to see how 10 lb feels like. The formula is:
(Deflection of belt) = (0.25)*(span length of belt between the two pulleys where the force is applied)*(perpendicular force applied on belt midway between the two pulleys)/(belt tension)
Force applied on belt will be roughly 10 lb when you push with your index finger but "calibrate" your index finger first. You should measure the deflection accurately by placing a ruler adjacent to the belt. Measure the span length between the tangent points -- between the centers of the two pulleys when viewed perpendicular to the belt with ruler held parallel to the belt.
Note that the special case of 160 lb of belt tension and 10 lb of perpendicular force applied on belt gives (Deflection of belt) = (span length of belt between the two pulleys where the force is applied)/64. This special case is all over the Internet but I wanted to provide the far more useful general formula here.
