Originally Posted By: MolaKule
Originally Posted By: Pontual
Tryclesilphosfate, is ashless, and cleans! An airspace product by the way.
I don't know what this comment has to do with Zmax. Zmax does not contain any TCP and has no connection to TCP.
TCP is used in aerospace hydraulic fluids and some phosphate forms are used in turbine engine oils, but that is about it.
Well Molakule, Tryclesil phosfate TCP and now TPP tryphenil phosfate is the aviation AW. Since Zmax is the same as Avblend ... There is supposed to have TCP as AW aicraft oil additive, the only thing FAA would clear to be used, as opposed to ZDDP by its clear ash deposits problems ... If you say there isn't, what would it have, mineral oil and linkite? So, what's linkite, A modified form of TCP? Likite sounds like almost a polymer for me (linked substance). TCP and now TPP are tri not poly, even though is a linked material.
Ah, btw TCP is (was) also used in reciprocating engines in aviation, like Shell Av100 and Phillips66, Engine oils that lacks in your list of hydraulic and jet oil.
BTW, TCP isn't used anymore, since TCP was replaced by TPP (tryphenil phosfate) in 1990, for public health reason. TCP attacks brain cells and gives brain cancer.
So I change my statment for TPP, is ashless and cleans
Please explain. I Don't mean to get you coffee though, eazy pal. Haha
