Just doesn't end...
Above ground pool. Has been cold here in NE. I saw one of the metal braces on the side of the pool buckle a bit. Noticed the pool pillow that holds the pool cover up deflated (hadn't looked or noticed). Only my second year with the pool so don't know all the ins/outs of it but I guess the pillow created a break in between the water and cover and prevented a full freeze? (I thought some of the chemicals we added for closing prevented a full freeze). No antifreeze, above ground, no lines.
So trying to decide what to do. I drilled a hole and ice is about 5 inches think. Should I try to drain a lot of the water or cut some holes and insert some 'objects' to prevent a solid freeze over the entire surface? Or...hey kids, I just made a rink.
Advice/recommendations.
