Originally Posted By: topbliss
The Ford 2.7 got 4 mpg more then the chevy and was the favorite of the 3 pickups tested. Of course its not going to get great mileage towing but you only tow 10% of the time. Read it
http://www.motortrend.com/roadtests/truc...rado/specs.html
Our ecoboost in an Escape absolutely gets as much if no more then the epa ratings and it an amazing engine, Ford really did their homework with the Ecoboosts and have a LOT to lose of they don't do what they claim to. The F150's are the money makers for Ford and they don't gamble on them. I would just on the F150 2.7 in a second if I were in the market for a truck. You have a buncha of 'sour grapes' people here cause they can't afford one so they poo poo it.. Don;'t be afraid of the new F150 ecoboosts, you will love it, if you can keep your foot out of the boost
Well I guess motortrend is sour grapes poopooing too, since they noted that while towing and under load the 2.7 got poor gas mileage. If you want to do V8 work, you get V8 fuel economy, simple as that. It takes a certain amount of energy to pull X pounds. There is a finite amount of energy in gas. To get an engine to do the same amount of work at the same rate, you have to push a certain amount of gas through it. The ecoboosts are pretty cheap, the 2.7 is a $795 upgrade over then 3.5 N/A and the 5.0 is actually more expensive. I am willing to bet you havent hitched a big trailer behind that turbo 4 in your escape. If you had, you would see that happens to that good gas mileage. I can see the ecoboosts getting great mileage unloaded. Loaded/towing, not so much. The only way to get better mileage while doing the same work at the same rate is to find a more efficient fuel source (diesel) or a hybrid. Remember, all turbos do is get more fuel and air into a small engine than can be naturally pulled in. They make the engine use more fuel and air when under boost! The efficiency gained through forced induction is just that you get a smaller displacement engine when boost is not needed. Turbos are not a magic bullet. That being said, if I was buying a new half ton, it would be the 2.7 ecoboost. Why? Exactly that, efficiency when not towing. I just wouldnt expect great gas mileage when pulling. Its an unrealistic expectation.
I did read it. You are missing the point.
