97tbird
Thread starter
Thanks - that model is one of the recommended ones on TWC page for our plan.
If I buy my own for Internet, is the set up complex? I guess I will have to get TWC for setting it up?
If the signal levels are good, what could be causing (or caused - see below about latest speed test) all this, I wonder?
in Any case, I think getting the modem replaced is not bad at this point, as the current one IS really outdated and not DOCSIS 3.
IDK why but just did a speed test and DL and UL both back to what it was..
BUT evening time will tell - that is when the problems start, although problems lasted till THIS MORNING this time, which is not usually the case.
