People usually call it "Asian Red" because, as I understand it, Toyota pioneered it and died theirs red. Eventually the other national makers followed suit and aligned their system metallurgy and coolant chemistry with this for commonality.
Your color, as mentioned, isn't a firm indicator of the chemistry. These are known as P-HOAT (phosphated hybrid organic acid tech), and HOAT (the pink is sans Phosphate, but they are compatible). You can use your manufacturer's stuff, or any substitute for Toyota red or pink (pink is longer service life). Toyota went to factory pink fill in, I think 2003, Nissan probably followed within a few years so yours likely has the P-HOAT in it if it is still factory. All are a bit pricier than normal ole' prestone green we knew long ago; different chemistry for different system metallurgy. Sources I go to for it are:
Carquest, factory Toyota LLC - $28/gallon concentrate
Napa, O'Reillys - $26.xx/gal Pentofrost A1 or
Zerex asian is pre-diluted and the same chemistry, so you are locked into 50/50 and I like a little more freeze protection than that (~-50F for 55/45 vs ~-30F with 50/50), so I use the concentrate along with dH20 from the supermarket.
Eutectic graph for anti-freeze:
http://theamcforum.com/forum/overheating-due-to-100-antifreeze_topic32939_page2.html
Depending upon how far "NE" you are, you may want 55/45, but if not way up there then 50/50 can work.
