Gasoilne standards established by the EPA only allow a 30 ppm of sulfur in gasoline. Diesel standards are 15 ppm. Both of which are dramatically low in the broad scheme of things. Gasoline sulfur allowances of a decade ago were 300 ppm for large refiners, and 800 ppm for small refiners. Diesel during the same time frame was 500 ppm. Gasoline sulfur levels are low enough that a low TBN oil would perform well. If a 10 TBN oil low SAPS can go for 25,000 miles in my diesel, not sure why an 8-10 TBN oil for a gas engine would not do equally as well.
