Good point about brake lines Paul. Is there anything else they can be made of?
Frank i only use Nicopp for all brake and fuel hard lines now. Great material that resist corrosion for decades and longer
Volvo, RR, Porsche, Aston Martin, etc all use it OE. Its not uncommon to find 30 yr old Volvo's with perfect brake lines. I looked at a late 70's in the junk yard with clean original lines in it.
Quote:
Volvo has been using galvanized brake plumbing since '71, and the Kunifer alloy C70600 alloy since '76)!
Kunifer C70600 is copper nickel, same 90-10 mix as NiCopp.
