Originally Posted By: Mter00s
After removing all PS fluid from the reservoir, will turning my steering wheel back and forth pump more fluid into the reservoir? If so, how many times will I be able to do this?
No. In order to move old fluid out of the system, you need to have new fluid go into the system. Drain, refill, turn the wheel, drain refill, turn the wheel, etc. until the fluid looks new.
