2 stroke spark plugs
by Greaser73
07/17/18 04:13 PM
Upgrading From 1/2 in Impact Wrench.
by George7941
07/17/18 04:00 PM
Just Bought a Chromebook
by Al
07/17/18 03:55 PM
Purchased new Stihl weed wacker today
by tig1
07/17/18 03:53 PM
Castrol Magatec 5W30 $14.57 Better than Prime Day
by tenderloin
07/17/18 03:19 PM
Midair collision in Everglades
by pilottravis
07/17/18 02:54 PM
will they ever be a push back on car technology?
by edwardh1
07/17/18 02:53 PM
DeWalt Dce100 blower
by Fitter30
07/17/18 02:09 PM
Grits
by Walmill
07/17/18 01:59 PM
Getting rear ended worked out!
by 14Accent
07/17/18 01:42 PM
Article on the use of thin oils and why....
by racin4ds
07/17/18 01:08 PM
DOT 4 Brake Fluid
by maverickfhs
07/17/18 01:02 PM
Amazon Prime 20% off Magnatec Prime Day
by Datarock
07/17/18 12:57 PM
Cooper Adds Solarus to the Starfire Line
by UG_Passat
07/17/18 12:50 PM
Resuing mower oil!
by KMJ1992
07/17/18 12:19 PM
2015 Audi Q7 Transmission Service
by rooflessVW
07/17/18 11:58 AM
Curious Questions regarding Engine Wear
by mbacfp
07/17/18 11:42 AM
Bridgestone Driveguard worked as advertised!
by LeakySeals
07/17/18 11:30 AM
Renewable Lubricants Inc. Dexos 1 gen 2 SN plus?
by 2James1
07/17/18 10:52 AM
2017 VW -- mildly cold Air Conditioning
by BAJA_05
07/17/18 10:50 AM
RYCOJO, Gunplt, bjay, javylsu, Jlb27537
65503 Registered Users
93 registered (28oz, 2015_PSD, ad244, Aero540T, AandPDan, Ag76, 7 invisible), 1674 Guests and 44 Spiders online.
65503 Members
67 Forums
287232 Topics
#3342296 - 04/14/14 10:23 AM Corrosion X
2008wrx Offline
Loc: CA
I intended to buy this to waterproof an electronic item's circuit board from water damage. Can someone share their experience? How does this thing work? Its forms a protection layer after dried off or...? Thanks
P.S I am thinking to use plastic dip as well..
#3342356 - 04/14/14 11:19 AM Re: Corrosion X [Re: 2008wrx]
gomes512 Offline
Loc: Chicago, IL
I use Corrosion X HD inside the fenders on my vehicles. Have not tried the normal variant though.
The HD stuff is a thick yellow viscous gel with the consistency and thickness of naval jelly. It has a very strong smell of lanolin, which I believe is the major component of the product.
Once sprayed, it creeps a good bit then settles in place after a minute. It's definitely persistent and does an excellent job blocking moisture.
Have you considered potting your item's circuit board instead? MG Chemicals has a thermally conductive compound that I've used on headlight ballasts.
#3342386 - 04/14/14 11:38 AM Re: Corrosion X [Re: 2008wrx]
2008wrx Offline
Loc: CA
I want to waterproof a radio control car electronic speed control (ESC). I guess Corrosion XHD is better.
#3342778 - 04/14/14 06:47 PM Re: Corrosion X [Re: 2008wrx]
jonny-b Offline
Loc: Norway
Corrosion XHD is better. If I were you, I would also take a look at www.polytrondirect.com and find Polytron PL.
It is really amazing in protecting electronic equipment.
It is extremely good in lubricating, as well.
But, as you know, it has to be experienced, to believe it.
It cost 16USD.
I use both products.
Edited by jonny-b (04/14/14 06:47 PM)
#3344564 - 04/16/14 01:29 PM Re: Corrosion X [Re: 2008wrx]
DSparks Offline
Loc: San Antonio, Texas
Good luck and dont forget the receiver and servos...
I do rc too....1/8 nitro and ebuggy and 1/10 2wd buggy off road.
#3414105 - 07/04/14 12:03 AM Re: Corrosion X [Re: 2008wrx]
Idahokid Offline
Loc: Northern Idaho
I work for kenworth and I see this product in a lot of shops.Its a blue,green can.It really works good so the de-icer they use on the roads around here don't eat up the wiring of tail lights and generally all over.It looks like carmel and almost as thick.lol.I see all kinds of tricks.
Don,t beleive everything you think.
1998 Expedition 5.4
1989 F150 4x4
FL820s
Motorcraft syn blend 5w20
#3554601 - 12/03/14 03:03 PM Re: Corrosion X [Re: 2008wrx]
SumpChump Offline
Loc: Upper Midwest by the Lakes USA
I have both regular and HD. The regular is great for a coat that "soaks" into a circuit board of walkie talkie , lock, battery terminal etc. the regular leaves an oily coat that is very trustworthy in it's soak tendencies.
The HD could be more robust for a splash area. It is indeed like caramel almost. Great garage door lube, really good. The regular and HD are very different when sprayed. The HD is much more likely to collect dirt particles and could cause electronic heat retention. But that may not matter in the least depending upon where and why it is used.
Such a thing as a 15k oil change or a lifetime transmission fluid!!??
#3555840 - 12/04/14 03:55 PM Re: Corrosion X [Re: 2008wrx]
Da Game Offline
Loc: Chicago
Anyone tried TC-11???
