Originally Posted By: BrandonVA
so i replaced them with nighthawk bulbs and they still suck!
i'm going to try out the hir2 9012 bulbs. Do I need to file off a tab or something on the plug? have any pics?
If the Nighthawks are dim, you have problems that 9012's won't help. You have to look at the voltage available at the socket, and check conductivity across switches, relays and grounds.
