I rank as follows :
1. Pennzoil High Mileage
2. *Max Life
3. Super Tech HM
4. Peak HM
5. **Defy
* Lower NOACK but the useage of Sodium is a cheap additive which I don't care for.
** As stated , Defy is not really a HM oil with seal additives , etc. However what I did learn is that a mix of Pennzoil HM and Defy may prove beneficial in a older Jeep 4.0L engine.
Thanks, Tom! Something for everyone in this group. Can't wait to see the follow-up.
I like what I see in Defy for flat tappet OHV engines. Second best viscosity at 100C while still reasonable at -30C, strongest Zinc, one of the better Noack's, strong TBN. Of course Pennzoil has to max out most of the add pack.
Originally Posted By: ChrisD46
I did notice that the PEAK sample tested was flagged for being over the allowable NOACK spec ...We'll see how that shakes out .
It was tagged but it was still in the expanded range. I would not worry about using it.
Interesting. I'm surprised at the ML viscosity, I would've expected a HM oil to be on the thicker end of the spectrum just because of how people always suggest going to a thicker oil to slow down leaks.
That's quite possible. I haven't seen any other ACEA approvals, although M1 HM might be A3 or something; we don't have that product up here so I can't check a bottle.
Mobil 1 5W-30 is A1/A5 and the 10W-30/40 are A3...
