Yet another Update.
I had a scanner plugged into the car. The scanner ran a battery of diagnostic tests. No codes. Then they drove the car with the scanner plugged in. Recorded 3 'data streams'. Still no codes. Everything checked out. The only error was 1-2 shift took too long. Each of the 3 recorded data streams resulted in the same 1-2 shift took too long.
Any ideas??
Thanks.
Any ideas??
Thanks.
