Rough idle on cold start
Kuwait
Weird issue with my Envoy (4.2L L6) the last two days. On cold starts first thing in the morning, the engine idles rough (like a single cylinder misfire) for about a minute then returns to normal. If you rev the engine whilst it idles rough, it revs smooth as glass. No codes are stored in the PCM.
Worth noting, same thing happened this evening after the truck was sat for 12 hours and I had no cruise control. Pulled over, killed the ignition and fired her back up again and I had my cruise control back. Possible throttle body issue? Thanks!
Possibly the throttle body needs to be cleaned or the(if this engine has one), the Idle Air Control Valve(IACV).
Research will help you fine where the IACV is!
Cleaning the T-Body with the proper cleaner may also aid in this idle issue.
Also, check for vacuum leaks!
This is just a start. Others will chime in with more helpfull information.
CB
+1
Co-worker of mine has a 2004 Trailblazer with the 4.2 and had the same issue but never went away warm or cold. Throttle body was caked full of black goo. Cleaned it up and it ran great.
Thanks for the input! The throttle body was cleaned roughly 3,000 miles ago and even then, barely needed any cleaning. It was almost spotless (engine's fed Euro V gas).
I monitor ECT constantly with my ScanGauge-II - at cold start ECT matches ambient temp and fluctuates between 190-195 F at operating temp - I guess that rules out the ECT sensor?
This may sound dumb but were they only looking at the throttle body on the visible outside of the throttle plate. My 1996 Ford Contour which burns no oil in 8500-9000 mile Oci's was clean on the visible front of the throttle body. Behind the throttle plate had black build up. After I cleaned it, it idles much better. Does it smooth up after it warms up? Mine now runs fairly stable idle, it only idles rough for a few seconds while still warming up, it only happens on the first stop after starting up. I'm sure my IAC valve should be cleaned but it's a PIA to get to so I'll live with less than perfect idle, but acceptable idle from a 4 cyl. I had no codes.
Whimsey
Try unplugging that and see what happens. Start with the simple stuff.
Ah..........but are you just looking at it from the air side? I think you'll find that the throttle body looks quite different on the engine side. The engine side is what regurgitates all the combustion byproducts and oily PCV fumes onto the throttle body.
+1
+1 just finished a 98 corolla with throttle body full of oil. Took off the throttle body and IACV, cleaned them both as they were both full of oil. Afterwards idle went from a constant 1400 to 750 rpm normal now. I did do an oil consumption fix, now I can barely hear the engine running and its revs REALLY smoothly.
How is your battery? If it's not in good shape it could cause a miss. I've had 2 different vehicles over the years that acted as yours does. Losing the cruise control was the tip off.
Have you checked for any corrosion at the distributor cap and coils and spark plug connections. Have had rough running and misfiring in the past due to corrosion and buildup at some of the connectors on wiring.
Found the culprit - we've been having some extremely humid weather of late and there was moisture in the coil in cylinder 1. Not sure how it got in, given I've generously applied dialectic grease when I did the plugs 25,000 miles ago, but I took this opportunity to pull the plugs out for inspection and reapply DG to all coil boots after blowing them clean with a compressed air gun.
That being said, I always clean my throttle body off the vehicle. In this case, it's drive by wire so I don't want to be messing with the plate. Removing it and generously spraying it with throttle body cleaner or brake cleaner does the trick, but it's always been clean with the gas I'm using.
Well done!
Thanks for keeping us posted on the results!
CB
