Post your latest oil change
2002 subaru wrx, 2L turbo, 118,000 mi. 5275 on this oci, drained early due to fear of purolator failure...was well founded. No make up added. seafoamed sump 2 days ago.
out: Rotella T6, P1 14460 (now with even more media tears!)
in: 4 qt RT6 + 1 Qt maxlife HM 10w40, OEM filter
Originally Posted By: sir1900
2006 Ford Freestar 4.2L
Out: VSB 5W20 and Purloator L25608
In: VML 5W20 and FRAM Ultra XG3600
Should read:
Out: VSP 5W20 and Purolator L25608
2004 Grand Caravan SXT
Out: Peak Performance 5w-30 + CD2 & Purolator PL14670
OCI duration: 4810 miles
In: .5 qt M1 5w-30 + .5 qt PP 5w-30 + 4 qt Peak Performance 5w_30
& MicroGard MGL14670
I was informed that the oil light was coming on. About 3.5 quarts drained out so it was not due to lack of oil. Perhaps the Pure One was overloaded with particulate causing lower idle pressure? Pure One is high efficiency and this engine is pretty dirty from prior extended OCIs with quickie lube service. I believe the MicroGards are rated at 94% which is probably better for this engine with 236k on the clock.
1998 Neon - Castrol HM out, and Chevron 5w30 in with a wix filter... runs really quiet with this oil!
Also have a pump that I use to change about 2 quarts of trans fluid at every oil change.
2010 Focus.
Out.
4 quarts PU 5W30 .5 quarts PYB. 5W20 Napa Gold filter.
In.
4.5 quarts Quaker State Advanced Durability 5W20. Motorcraft filter.
1985 2500 Dodge Van 5.2L 216,142 miles
Out--who knows but it was black as coal & only 2 quarts drained out with a OCOD filter.
In--5 quarts Valvoline Maxlife Synthetic Blend 5-30 & L3001 filter
New to me '01 4.0 Jeep Cherokee XJ winter beater - 157k mi
Mobil Super 5k 10w30 and Purolator Classic 14670
Audi a3 2006 155k mi
Mann Filter & M1 0w40
04' VW Beetle TDI - 158k
About 8k miles in 10 months
Out: Dealer 5w30 507.00 VW spec oil
In: Pentosin High Performance II 5w40 505.01 VW spec oil
8 quarts of Amsoil SS and an Amsoil filter for the F150. Slight overfill from the 7.7 quarts specified, but 9oz of oil extra still leaves it slightly below "full" on the stick.
2004 Toyota highlander v6. 113900 mi
oci 8570 miles.., still read 3/4ths on the dipstick!
out: PU 5W-30, Toyota filter
in: 5 qts PU 5w-30, Toyota filter
Yesterday on the Fusion:
OUT: QSUD 5w-20. In use for about 9 months and 8,855.3 miles (longest I've ever gone!), and a Fram TG3614 filter.
IN: 5.3 qts of Napa synthetic 0w20 and remnants of some Mos2 additive, and a Motorcraft FL-910s filter.
So, a story with this oil change.
I had extra Amazon money, so I bought an AEM Dryflow cone filter. I had installed a cold air intake and used a generic cone filter, figured I'll change it out. Put 3k miles on it. When I went to install the AEM, this came out:
Yeah, the center cap fell out. [censored]. it's just glued there. So somewhere in 3k miles, this thing is useless. I'm lucky it didn't get sucked up.
So I was angry, at myself, at things in general. I begrudgingly drained the GC out of my 2zz-ge that only had 3k miles on it, and put in 4.8 quarts of Peak Conventional 5w30 and a Purolator Pureone.
Should I run this for a full OCI or shorten it because of probable contamination? I have PU 5w30 on deck.
Lesson learned, stay away from generic garbage.
Just run it the normal duration.
