Failed CA emission - high NO
Bay Area, CA
My '96 3.8L Camaro failed it's first California emission test. It's gotten near the maximum allowed before but that was a HC issue which wasn't an issue this time. This time it failed due to high NO numbers.
I don't have any CEL or any rotten smells coming from the car. Mods are an intake, headers, high-flow cat and exhaust system but I've had all those the past 2-3 checks and haven't seen numbers like this. The NO numbers were about half in the two previous emission checks.
Where to start? Plugs, wires, fuel filter, O2 sensors, etc are all under 2 years and less than 12k old. Cooling system just drained/refilled. The EGR valve, as I understand, might be a culprit and it's probably near 8 years old and 80k on it though again, no CEL.
What else would contribute to a doubling NO test count?
EGR likes backpressure. Root out the passages. Cool the engine off... rad flush.
The entire EGR system should be inspected.
Also, how hot was your car before the test?
This is important for NOx.
If the EGR system isn't plugged or have a bad component, then you will need a new convertor.
BC.
Typical and common things to consider:
Vacuum leaks, lean mixture, over advanced timing, in-operative EGR valve, plugged or partially plugged EGR passages, aftermarket non-CARB converter.
I'd look at the EGR system first.
I'd put a lean mixture down on the list of things to look at. You do have excess O2 but I don't think it's enough to affect the NOx readings.
If you have your previous year test results, it might help to compare the measured numbers. Perhaps there's a trend that might point you in the right direction.
I'd throw in the time table of when you made the engine mods for comparison purposes as well.
BC.
Should have added that info about temperature.
I had driven the car on the highway about 30 miles to the testing shop. It was shut off for approx. 5 minutes before they put it on the machine.
Is it likely the EGR valve or cat?
Engine mods were in '06 so I've had three passing emission tests since then.
Dug up the last three emission tests, NO is really the only thing that has consistently been high.
2008: 15mph measure was 394, max is 424. 25 mph measure was 138, max is 711.
2010: 15mph measure was 209, max is 424. 25 mph measure was 312, max is 711.
2012: 15mph measure was 159, max is 424. 25 mph measure was 248, max is 711.
Since it's such a rarely driven vehicle, I haven't had to change much on it due to mileage.
Cat is CA legal, made sure that part was kosher before I purchased it.
Higher than normal NOX emissions may be caused by:
-an overheated engine
-Lean air/fuel mixtures
-Vacuum leaks
-over advanced ignition timing
-Defective EGR system
The EGR is the first place to look at.
Probably just needs a very good cleaning, not just the valve, but all the ports, hoses and lines. hose them with carb spray.
A good run on the freeway would definetely help break that stuff up too.
I'd also do a seafoam de-carbonization and also a good freeway run.
I wouldn't be to concerned with the cat being faulty at this point. Your HC's are very low and CO is next to nothing.
This really is pointing to a plugged up EGR system.
Looking at
Originally Posted By: Chris142
it may be a bad cat. especially an aftermarked cat
Agreed. My 318i doesnt even have EGR. Failed NOx once, replaced it with a Magnaflow, barely passed. Replaced it with an OEM one, and passed with flying colors...
http://www.bobistheoilguy.com/forums/ubbthreads.php/topics/915639
ONLY EVER BUY OEM if you plan on doing anything besides dumping the car.
I learned that at my own expense. The aftermarket cat was barely good enough to improve numbers compared to my OE cat which was not converting NOX. New OE, NOx was at 7. All the other measured items had substantial improvements percentage wise but nowhere near the swing in number values.
I thought you generally didn't have to go on the rollers in California anymore for year 2000+ cars. Just visual inspection and a code check.
Anyway, pressure check your cooling system and check for leaks. A hot cylinder head will raise NOx.
Leaner mixtures result in higher NO_x and lower HC. Richer mixtures result in lower NO_x and higher HC. If you can adjust the mixture, do so.
Check the EGR system, which reduces the NO_x. See if it's working. If it's not working, it could be because of an EGR valve blocked with heavy carbon deposits or a torn EGR-vacuum-modulator diaphragm. Carbon deposits on the EGR valve can be removed using a flat screwdriver as a pick along with a brake-cleaner solvent.
In your car, the most likely candidate is the carbon deposits on the EGR valve. It also doesn't seem to have an EGR vacuum modulator but a solenoid. So, check if the solenoid is working as well.
Thanks for all the input everyone. I've never failed an emission test before (come close, but never failed) so it's something new to worry about.
I've had the car for the last 14 years and 140k miles and haven't cleaned any EGR related items, just replaced the valve many many years ago. Come to think of it, I don't think I've ever replaced any vacuum hoses/lines either.
And in case anyone else is a visual person like me, here are the previous three passing tests.
My Cherokee passed two tests with a cheap part-store cat (Walker, I think) without a problem. And note: the OP's car PASSED twice with the aftermarket cat in place.
-Vacuum leaks
How does the EGR cause a lean condition; is it caused by the EGR valve being stuck open, or closed?
part of the smog test is a test of the egr. if the smog guy did his job and did the state mandated test and passed the egr then the egr system should be fine.
I looked through my past smog tests, they all only show "VISUAL EGR" as a PASS and an N/A to "FUNCTIONAL EGR". It looks like they just check to make sure it's physically there.
-Vacuum leaks
EGR valve doesn't cause lean conditions. It decreases the combustion temperature by recirculating the exhaust gas into the combustion chamber. Decreasing the combustion temperature decreases the NO_x formation, as high combustion temperatures increase the NO_x formation.
Lean conditions (excess oxygen), unrelated to EGR but related to vacuum leaks or fuel-system or emission-component (such as O_2 feedback system) problems, also increase the NO_x, as NO_x is formed by oxygen reacting with nitrogen.
OP might have a carbon-blocked EGR valve or some fuel- or emission-system problems as I mentioned. I had a fully carbon-blocked EGR valve once. The stuff was really, really hard, but I was able to fully clean it with a flat screwdriver (used as a pick) and brake-cleaner solvent.
