Originally Posted By: ChrisW
Originally Posted By: rslifkin
Camber vs tire wear depends on the car, the tires and driving style. Different combinations of the above will require different amounts of camber for even wear.
Toe, however, can cause really screwy wear if it's off. And too much toe in or out can drastically magnify camber wear as well.
With good toe, it's surprising how much camber you can run and still get even tire wear, especially if you aren't a grandma in corners. Heck, I've seen cars with sticky performance tires that are driven hard, have 2 - 3+ degrees of camber, slight toe out and still show outside edge wear like there's not enough camber.
I think some of the older Alfa Romeo which had on the order of more than 4 degrees of negative camber but set at zero or close to zero toe wore tires evenly.
Some cars are terrible when it comes to dynamic toe, that is, how much the toe changes when the vehicle is in motion (compression/rebound) and of course that's all relative to that toe will change as the vehicle is in motion to accommodate the necessary handling/angles for that given motion. When I had a 98 Audi A6 in the family, I even recall from the Bentley manual that there is a procedure to adjust dynamic toe, and the tie rod end could be adjusted up/down in the knuckle to adjust the angle relative to the ground and the angle of the control arms.
I see too many newer vehicles come through the shop with what I'd consider to be aggressive toe settings from the factory. Hyundai, Honda, Toyota, etc heavy inside shoulder wear and the rest of the tread is good. It stinks knowing that if/when I buy a new car I'm going to be taking it straight to my alignment guy and have it checked and adjusted.
I had my focus aligned to the inner edge of the spec. While mine was in spec, it was on the outer edge of the spec and would burn the RR tire off pretty quickly.
I notice a lot of newer SUVs and such with agressive camber. Half of the Pilots, CR-Vs and Odyssey vans out there are riding on the sidewall with any sort of load. The other one I noticed is the Santa Fe.
I am going to dial out the rest of the camber on the focus now that the toe is set.
