You need to change your oil filter, but the filter won't budge. You find out they used Loctite 2620 Ultra High Temperature, High Strength Red Threadlocker on the threads!
You also find out the filter is a K&N (with that nut on the end)and the person installed it with a 250 ft/lb impact gun.
Then you realize that guy is a moron!
What would you do?
What would you do?
