Post your rpms at 70mph
Originally Posted By: lawman1909
Off topic I know, but you should try MC synthetic blend 5w-20 in the CV. We use that exclusively in our squads and change every 4K. That 4k could be 6-7k if the cars weren't idled as much and weren't doing near redline runs every day for calls.
Thanks for the tip! Everything I have read about Motorcraft oils here on BITOG is nothing but positive. It is really a great oil for a great price.
In the CVLX its about 1800RPM with 2.73s and larger 255/45R18 tires.
Its going to get 4.10s here in a month or so. It would bring it up to about 2600RPM.
The CVPI also has 3.27s as your '09 so it is the same 2000RPM.
2004 Honda Element
~ 3000 RPM @ 70 MPH
Slow and thirsty, but still looks new with 150K.
2010 focus 3,000 at 70 a little higher then i like but only a 4 speed with overdrive
'13 F150 3.73 gears, six speed auto and 265/70R17 GY Duratracs - 1800 RPM @ 60 MPH.
'08 F150 3.73 gears, four speed auto and 265/70R17 GY Duratracs - 2000 RPM @ 60 MPH. Most of the RPM difference is because of the Detroit Locker (loose backlash).
