New To BMW and Synthetics
Originally Posted By: edyvw
0W20 oil in my dictionary does not exist, regardless how short distance is and how cold it is.
What do you think the problem would be? My BMW calls out a 20-weight BTW, up to 20 degrees. But that was the 20-weight of the time, surely TGMO 0W-20 would be an improvement?
That chart exists in all European manuals.
I owned BMW 325 E30, 325 E36, 520I, 525I E34, and there was always that chart, but used in Bosnian winters 10W40 or 5W40, and those winters are on par with Canadian, while mountains see temps lower then -35 sometimes.
If I plan to keep a car for long time, and I always do, I stick to thicker oils x40, while only in last several years I used x30.
And somehow, all my cars had 200,000 miles or more before they were sold.
You can use 0W20, but is your driving 100% 2-3 miles long?
If I knew that someone used X20 or x30 non Euro spec in BMW, I would never buy that car from that person, just my preference.
Not understanding the concept of operational viscosity is not unusual, but bragging about it just reveals a closed mind.
Fortunately some brighter members are willing to learn something on the subject.
It doesn't apply to this model but the more powerful N20 BMW turbo 4 that is currently spec'd the BMW A3/B4 5W-30 has also the BMW approval of a 0W-20 for not just winter use but year round. Those with an open mind that are interested can check it out below:
http://www.bobistheoilguy.com/forums/ubbthreads.php/topics/3394810/1
LOL, in ANY European car after 10 minutes you would have 3rd degree burn touching filter.
No, I have a 7 series BMW with a 6.5L sump and finned aluminium pan, and it never get hotter than warm to the touch in winter.
If it doesn't apply to the model being discussed then it is pointless to even mention it surely?
I would never hamper my car with an oil with such narrow operational limits.
What is to be gained?
A 5w30, 5w40 or even 0w40 will work perfectly well in sub zero temperatures.
But will not need changing if temperatures increase.
I have experienced high oil consumption with a BMW diesel engine many years ago on 0w40 that ceased completely on 5w40.
It was run with 5w40 summer and winter and had north of 250k on it when i sold it at 4 1/2 years old. I did only own from 80k onwards so not sure what was used by Vauxhall, it was an Omega with the BMW 2.5diesel lump, probably 10w40 Castrol which was the usual oil for many Vauxhalls back in the 90's
kschachn said:
In Europe distances are shorter. Before moving here, sometimes I would make at most 2 miles a day! Temp gauge would not even move during winter in such short distances.....
Also, that chart says x20 oil in certain temperature. What if temperature goes from -20 to 60's and you have to make long trip?
Even in the summer an oil temp' will hardly move if you're only driving 2 miles a day. Even in the summer you'll typically need at least 15-20 minutes to see even 75-80C oil temp's so even a light 0W-20 will still be way heavier than necessary.
What happens if the ambient temp' jump to 60F? Well as unlikely as that may be in the dead of winter nothing happens. Ambient oil charts are conservative in that the manufacturer knows oil temp's won't be able get above a certain temperature and higher road speeds actually reduce oil temp's even further.
The bottom line is not ambient temp's (which has more to do with cold starting), but oil temp's or the real bottom line oil pressure. A long road trip could allow oil temp's to rise to normal at 60F but it's highly unlikely that your oil pressure would drop below the minimum required.
I find it quite amusing, particularly with Bimmer owners and of other high performance oriented makes, that they have no problem seeing oil temp's approaching 150C on the race track with a 3.6-4.2cP HTHSV XW-40 motor oil but wouldn't consider a 20 grade oil with oil temp's at even 90C when it's HTHSV is going to be in the 6-7cP range at that oil temp'. It totally defies any sense of logic.
This is an oil forum, and we are having a discussion so its not pointless.
Quote: What is to be gained?
For one thing, MPG. My gas consumption goes up 40% in the winter and that is mostly due to thick fluids caused by the cols weather.
No offense, but what you call winter in the UK has nothing in common with the weather we have here
What's to be gained?
It's not just about improved fuel economy, it's about optimized lubrication. It's unfortunate that most cars aren't equipped with oil gauges which tell's the whole story. Even the lightest 0W-20 is way heavier than optimum until you can get your oil temp's up to at least 75C. And even in a mild winter, those that have gauges are surprised at how infrequently oil temp's hit a low normal temp'. Running a 40 grade oil you need oil temp's at the high end of normal before your oil pump is even out of my-pass mode , forget about being even close to an optimum viscosity. All that excess viscosity reserve is to deal with very high oil temp's that never occurs unless you've got the throttle mashed 80% of the time which is virtually impossible in most regions of the world outside of a race track.
15-20min to see 75-80 in summer? I reached few days ago with 335i xDrive full oil temp in 4 miles of city driving, and this is not very urban city, so there was no stop and go.
What you talking about? As soon as oil reached optimal temp, rpms were in red line.
If you are buying Toyota Camry, i could agree with X20.
Buying BMW and driving it the way it suppose to be driven on x20 oil? Yeah right.
Most BMWs due to their exposed finned ali' sumps have a hard time generating even low normal oil temp's of 80C in a Cdn winter. I've run M1 0W-20 in the winter in my Bimmer for that very reason.
The Audi would have been pretty safe in that regard, too. That thing could appropriately moderate oil temperatures.
kschan: I think it's possible to do, given you spec chart, which is much the same as what Audi did, in fact almost identical when it comes to the temperature ranges. It notes that you can use 15w-40 down to -20 C. My Audi's manual said the same thing and I was skeptical. Needless to say, I didn't try. I don't like seasonal oil changes, and given that your vehicle doesn't specially call for an approved lube, you have a few choices.
You could use 15w-40 in the summer and ILSAC 5w-30 or 10w-30 in the winter. You could probably get away with using the latter two year round, but watch consumption and pressure.
You could grab an approved lube or reasonable facsimile thereof. That would include the real BMW approved A3/B4 type lubes such as GC (and its brothers) or M1 0w-40. At least you're getting a better VI than a 10w-30 or 15w-40 and won't have to mess around with seasonal changes. Given that your engine doesn't specially call for approved lubes, you're also free to experiment with reasonable facsimiles such as Delvac 1, RP 0w-40, and so forth.
I know that a good 0w-20 could likely work well in the winter, particularly a cold one. I just don't know how long I'd want to stretch that into the summer or how safe it would be for how long, and without oil pressure gauges and relevant specifications, it would be hard to even begin to guess.
Maybe you should read the oil article by Dr. Hass. He runs 0W20 in his Ferrari Maranello without issue.
Good for him!
At least of the time of writing, he was not using an ILSAC rated 0w-20. Red Line and the like are essentially cheating, if you ask me.
Even when the manual says you can.
I don't know how I missed that. I'm going to call you on that one. You're saying that the majority of your increased fuel consumption in winter is due to thick fluids, as opposed to longer warm ups, worse rolling resistance in snow, winter fuel, and so forth? How short are the trips you take?
That's right. If something like M1 0w-40 existed when that BMW chart was created, that whole gamut of different oil grades and temperatures could have been replaced by this one oil.
Sometimes, the warning about extra oil consumption and/or fast speeds is printed in a different spot, too. Usually, there is some sort of warning about using 20 grades in the things. The Audi had wording to not panic about the ambient temperature going up, but to monitor the oil level more closely.
He also:
A) short trips the car
B) does NOT beat on it
C) has the money to replace the engine if he nukes it.
Since I do NOT have a spare $20,000 kicking around to replace the engine in my M5, I'm certainly one of the people not willing to experiment with viscosity choices much thinner than specified by the OEM. Particularly given that nothing of detriment is happening by running the 0w-40 year round. And fuel consumption, given how I drive the thing, well, my right foot has a far greater impact on the amount of gas I go through than the grade of oil in the pan.
VW/Audi, Opel (GM) etc, wrote in their manuals that consumption of 1ltr of oil in 1,000km is acceptable rate, and that is if you use recommended oil. So would you say everything is normal because it says in the book?
Using such thin oil in older car means recipe for dirty garage floor after you turn of your car.
And yes, I think that using such thin oil in BMW is ridiculous.
My recipe is sticking to xW40 or very thick xW30 oils in Euro sled.
Which is EXACTLY what they did when they started spec'ing LL-98 , LL-01....etc. BMW Synthetic 5w-30 (and its equivalents) replaced that chart.
You're right! Those are all factors as well! But I take the same length of trips in the winter as summer
No BMW 5W30 here and not available in most countries. One to ponder....
