My daughter plans to take one of the cars out of state for school. Despite how may reminders I give, it may be 2 years and as many as 20,000 miles before it gets an oil change. My 2002 Focus had to endure that for years with conventional oil, and still runs, but I really want to try to do better for this car in case it does get neglected. I plan to use a full synthetic oil.
The oil filter is where I need advice. Any recommendations for a good filter?
The car is a 2001 Focus with a DOHC Ztec and 220k miles. Based on past usage and knowing the lower it gets the faster it gets low, I figure it would be almost a quart low at 20k miles. So far the only filter I have seen for the DOHC is the Mobil 1 EP M1-211 that they claim is good for 15k miles.
Fram does not list an Ultra Synthetic filter for the 2.0 Ztec. I have seen on here that some have used the xg3600 for the SOHC engine with good results. The bypass rating is 2 psi lower on the xx3600 series of Fram filters. Could that make much of a difference If the oil and filter are run too long? Any other filters I should consider? I almost got the Mobil 1 EP filter, but since the car isn't leaving for a month, and the filter is not on sale, I figured I would ask for opinions here first while I look for a deal.
