Pulled this code yesterday. The vehicle is an 03' Altima 2.5L with 97K.
All I got from the web was that for Nissan it's about the "Vacuum Cut Valve Bypass Valve" who's it's function is to prevent engine vacuum form being applied to the fuel tank except for self test purposes, and it can trigger SES light either from being damaged, clogged or being incorrectly installed.
Does anyone have experience with this condition? If so is it usually an quick & easy diagnosis or one of those requiring multiple steps with several drive cycles in between?
Also are there any adverse side effects from continuing to drive with this code? (other than being unable to pass an emission test, which in this case wouldn't be due until Jan 2016)
