is shell the only one with a cj-4 & sn oil out the
quebec canada
I know all oil say they do.but i only visually my self on the bottle saw the rotella t6 0w40 having the cj-4 and sn in the sae thingy.i think mobil delvac1 le5w30 also is.but are there other?this list is probably gona be short .would be a good idea to know them all
It does not really mean anything. You can tack just about any valid gasoline category on the end of a CJ-4. It will still kill your catalytic converter.
Please lets not dot the i and line the t on this thread.just a friendly list of the known oil that have sn and cj-4 or more on the bottle the way the standard ask .
Why would it kill his cat? Rotella actually has weaker add pack and lower sulfated ash than something like M1 0w-40 which is API SN rated for gasoline engines. I don't hear any gasoline engine cats dying by the dozen due to using it.
and yet, Shell has said that Rotella should not be used in catalyst equipped vehicles.
Why?
XXw40 SN oils don't have the same SAPS limit that XXw30 and XXw20 SN oils have. Since most conventional HDEO is 15w40 and most synthetic HDEO is 5w40, that would be why there are API SN approved diesel engine oils.
That is why you can have an HDEO that still meets SN standards.
This is also why you may find more than 800 PPM phosphorous in 5w40 or 0w40 oils formulated for European gasoline engines, and some light European diesels such as the ones found in VWs.
Why?
Yes, it's puzzling, especially that they list this under Rotella's benefits section:
Quote:
Emissions System Compatibility
Advanced low-ash formulation helps control blocking of or poisoning of exhaust after-treatment devices, helping maintain vehicle emission compliance and engine fuel efficiency.
If Rotella should not be used in catalyst equipped vehicles, then why isn't there a big warning label on the bottle stating so?
Ty for the mag.
You cant label an oil sn if it doesnt pass the test required.last i checked catalysor was one requirement.i ll need to look into the sn standard tho
http://www.oilspecifications.org/articles/api-sn.php according to this,it look like the viscosity rotella t6 0w40 is in a gray area. It is in the others.so basicly this means only mobil delvac1 le5w30 meet all sn and trucking criteria?outch .talk about highly specialised field of work.from what i can understand .for the sn oil to be catalyst friendly it has to be ressource conserving(sn-rc)dont we love it when there are gray area
"Should not" or "not recommended" (when there are less risky alternatives from a manufacturer's point of view) and "DO NOT" are two different things. I'm going to make a guess and say that as long as your engine is not a huge oil burner it won't make any difference. Many of the dual rated oils are also marketed as "a single oil for your mixed fleet", so on one hand they promote it but on the other they discourage it.
I think that like most any consumer product, you don't have complete control over its use once it gets into the marketplace. As a result you do what you can through labeling and product recommendations to mitigate any potential problems. From the manufacturer's point of view there are less problematic oils available that they would rather you use.
Why?
and yet, Shell has said that Rotella should not be used in catalyst equipped vehicles. Why?
Shell is nuts, that's why. They get a modern spark ignition certification yet warn to not use it in vehicles that need SN oil. Go figure.
Actually, though, most of the oil companies warn against North American customers using dual rated oils in catalyst equipped vehicles. I've seen that from Chevron and Petro-Canada, too. XOM seems to have less of a problem with it, and recommends Delvac 1 ESP 5w-40 (and other HDEOs) for high performance gasoline applications.
yvon_la: As I stated elsewhere already today to much the same question, if an HDEO is relatively new, it'll probably have an SN rating. If it was something that existed in CI-4 and CI-4+, the upgrade to CJ-4 was the big one, and SM remained. HDEOs that are more recently available in North America seem to have the SN specification. And no, Delvac 1 LE 5w-30 is not resource conserving. It never will be, either. It cannot be GF-5 rated. It's low in phosphorous, but its HTHS is 3.5 or greater as per its CJ-4 specification, which is listed first on the bottle. Therefore, its HTHS is too high to obtain ILSAC certification. Listing CJ-4 before SM or SN allows them to get away with higher phosphorous, if they so choose. Lacking ILSAC certification altogether is because of the thickness that goes with CJ-4.
We've been through this before. An oil can be SN, but not resource conserving (ILSAC rated). We see this in monogrades, and in multigrade 40s and 50s, and certain multigrade 30s.
But, to be ILSAC rated, it has to have the API rating with it. You can have SM. You can have SN. You can have SM/GF-4 and SN/GF-5. But, you cannot have GF-4 or GF-5 on their own. Again, though, you will never see a resource conserving (or ILSAC rated) CJ-4 oil. The specifications are mutually exclusive.
Ya thats where rotella got me.just saw the bottle on the website.i ll double check tomrrow in store where i am but it look like you are right it is an sn/cj-4 oil but isnt ressource conserving .wich is one very important thing for cars now a day .ty for help .i hadnt understood before.
I may be somewhat out of the loop, but I have not seen a diesel OEM requirement for SN. Just CJ-4, or one of their proprietary specifications. So I am not sure why it would matter if a HDEO was both CJ-4 and SN. Maybe someone could elaborate further. I just get a CJ-4 for my diesels, and an SN for my gassers. But this will all be changing again soon anyway. The new HDEO standard will be out in the next couple of years and will throw everything off. Right now it is being referred to as PC-11, but they have not confirmed that will be the actual classification number.
My vehicle is a 1997 T4R, SR5 and I've used quite a few 15w-40 HD engine oils, with both the SL, CJ-4/SM designations, usually blended with some 0w-20 or 5w-20 SM, PCMO with no ill effects.
The sole reasoning for using the HDEO was because of store clearance and/or rebates as an added perk. Lots of the HDEO, after clearance and rebates, was very close to FREE or actually Free, except for postage.
My vehicle is equipped with a Cat Converter and seems to run fine after many OCI's of HDEO blended mix.
I've used Shell Rotella T-5, T-6, Triple Protection 15w-40 and 10w-30 blended with Formula Shell 5w-20 API-SM and SN in both conventional and synthetic for PCMO. All the Shell HD engine oils had the CJ-4/SM or the SL designations on the label.
I've also used quite a bit of Mobil Delvac 15w-40, Chevron LE 15w40, Castrol and Valvoline blue in 15w-40, all had the API-SM or SL designations,.....all were blended with some light synthetic/conventional PCMO in 5w20 or 0w-20 weights.....usually all in the same family.
So for SOPUS to put the notification on the label, for users of the T-6 product, about potential Cat converter damage is just a CYA for disclosure. I would never attempt to put any HDEO in a modern engine designated for API-SN PCMO, unless it was OK, via the owners manual.
My vehicle runs very smooth with HDEO blended with a light synthetic. In fact, I would not be surprised if the HDEO blend has kept the engine exceptionally clean, after 2 Kreen treatments. IMO...you really can't beat the powerful detergent add packs, formulated into these HDEO's. That's my 2 cents on the use of HDEO in older engines.
I guess I better get on changing ALL my CATS on ALL my vehicles, My WJ has seen Rottella since 35K and at 130K I replaced the CAT due to its age NOT because it was failing. Now pushing 150K and runs like new. Same deal with my last XJ and the ZJ before that and my Dakota......
This [censored] comes up once a year.....
Not quite true. ILSAC approval of a GF-4 and its use on labels expired automatically 6 months after the approval of GF-5/SN. The seal cannot be used after that point, but you have 6 months to clear inventory.
And as going back to the original question, read the API regulations and what they allow you to tack on after the "/".
I don't have the current instructions on my hard drive, but this was how it was described in 98: "Product Qualifications
The API SH designation has been superseded by SJ and is no longer licensable as a “stand alone” passenger car engine oil category. However, SH can be licensed in conjunction with a “C” category as long as the “C” designation is listed first in the API Service Symbol."
Here an explanation on the 2009 application form (today everything is on line). Note that they refer to the API/ILSAC certification mark as a determinant in whether or not you can tack on the SM to a CJ-4: "If CJ-4 precedes SM or SL and there is no API Certification Mark, the CJ-4 limit of 0.12 applies."
And yes, I see lots of clogged catalytic converters here from the use of mixed fleet oils in modern cars. A major car dealer chain is the Shell importer and had huge problems, finally importing the SN oils from the US to solve them.
I was just simplifying a bit. Yes, you won't see any new SM/GF-4 oils come out (someone should tell Walmart Canada about getting rid of old stock, but I digress).
I was simplifying with respect to what one will usually see in the Canadian market (and even the U.S. market, with respect to the majors). Imperial Oil got rid of all the older HDEOs, and they did so a long time ago. Every Mobil branded HDEO is either CJ-4/SM or CJ-4/SN (or with no gasoline spec at all). Stuff that came out when CJ-4 rolled out is CJ-4/SM. The newer stuff (like Delvac 1 LE 5w-30) is CJ-4/SN.
There also seems to be some repeated confusion on the board about Delvac 1 LE 5w-30. It has been referred to as an HDEO that is also an ILSAC rated oil a couple times, and that's clearly not the case. The product is low phosphorous, but cannot meet the HTHS requirements of ILSAC, of course. The point is that CJ-4/SN/GF-5 (or CJ-4/SM/GF-4 a few years ago) would be an impossibility.
I haven't seen a plugged cat for a few years. Is oil consumption an issue down there, Richard? The plugged cats I used to see happened to be in some serious oil burners.
Oh, more questions, Richard. How long were pre-CJ-4 lubes available in your neck of the woods, and are they still available, and what pre-CJ-4 certifications were recently available or still are available? Like I said, up here, Imperial Oil got rid of CI-4+ and earlier stuff so fast, I couldn't believe it. Oddly enough, the same company took the absolute longest in rolling out SN/GF-5 lubes and finally has some M1 0w-40 SN out on the shelves.
Most light-duty OEMs are recommending ILSAC oils bearing the API Starburst (or their own OEM specification in other cases). You'll never see them recommend any specific API category because the premise of the system is that it is backwards compatible.
Talk to any oil person at an OEM, and they'll tell you they put the API Starburst in the owner's manuals specifically so customers are always using the most recent ILSAC categories in their engines - e.g. even if the car was factory filled with GF-4, they recommend you use GF-5 oil.
But to answer the original question - there are plenty of additive chemistries that "technically" can be licensed as CJ-4/SN. My company has multiple 15W-40 HDDEO brands which are licensed as CJ-4/SN with APIs engine oil licensing system.
