So THAT'S why there's a wobble
Nick1994
$100 site donor 2024
Phoenix, AZ
I've been wondering the past couple weeks what's been with the wobble in my front end. I was 99% sure it was a tire, I just hadn't looked at them in a couple weeks. I figured they were out of balance and was just gonna swap the 2 up front. I had to do it at night cause it's 105 degrees in the day time. These tires have around 40k miles on them and are Bridgestone Insignia se200's. 3 1/2 years old. I see no quality in these tires and will not run a Bridgestone again, I've seen them die prematurely on other cars as well. And yes I know at 40k they are due for replacement regardless and the bubble isn't just the reason I won't run Bridgestone's, these tires just all around suck.
I'm interested to hear what people say the cause of this was. Was the tire properly inflated while it was in service?
Me too. Phoenix doesn't have bad streets either, not really any potholes. I've had the car since 185k miles in November. Since then I keep them at 36 psi and let them run down to around 34 then pump them back up. They weren't low when I bought the car and I assume the guy took care of it pretty good, he spent over $2,100 (yes, $2,100) in May of 2013 getting a power steering pump, radiator flush and hoses, transmission flush, all 4 new struts and an alignment.
I bought the car 6 months after he did that for $1,700
Also he got a Maaco paint job about 6 months prior.
Originally Posted By: spasm3
whats the date code? looks like it has some age on it!
Date code is (5110)
So right at 3 1/2 years.
Hello, I'm with you Nick. In my case Bridgestones (a set of 4 Turanza with Serenity) which were touted as the cat's meow-and priced to match-disappointed the dickens out of me.
How an irregularity gets built into a tire is anybody's guess.
I was told by a seasoned tire guy that tires don't necessarily wear evenly. I think that's a good tidbit to remember.
You're far from being the first guy to experience a crooked, wavy tire let alone one made with a less-than-perfect batch of rubber compound. Kira
I had 2 tires do that out of a set of 4. Sam's Club Goodrich T/A's .
They are ~8 years old, but I also have a similar set of Sam's GY's about 9 YO that are still good. Both sets have 4-5/32" tread and even wear.
Wayne
A couple of thoughts:
THAT is very likely a belt leaving belt separation - what is commonly called a tread separation. Yes, the Ford/Firestone kind of thing.
I'm guessing the tire has a cap ply and that is why it hasn't created a flap yet.
Heat is the great tire killer. Needless to say, Phoenix is likely the hottest major city in the US.
Second, the condition of the tire looks rough, but there aren't any tell-tale cracks which is the usual way to determine the condition of the rubber (A lesson here, folks!)
Belt leaving belt separations are fatigue type failures and are rarely caused by a defect. They are usually caused by some deficiency in the design (belt edge placement, rubber gauge, that sort of thing) Lawyers like to call these design deficiencies "defects" - and even NHTSA uses that term - but that's not the way normal folks talk.
Underinflation and overloading can lead to those kinds of failures - and it would take more than just a few photos to be able to see if that is perhaps the case (Oh, and with all due respect to Nick, if I looked at the tire, I would make an assessment independent of his assertions either way. The tire would tell me if it was underinflated or not.)
It is also possible that a cut could cause that as well. Steel belts do rust - even in Phoenix.
I'd definitely replace them anyway - even if they weren't having the belt separation issues, they are way past the point a tire should be replaced (in my book)
Looks like hot pavement effects. Very similar to what I see on passenger car tires in the Caribbean. No excuse for the bubble though... Cant say how it was caused, but wouldnt be secure on those, even in the desert...
If you ever had a flat tire repaired with the "rope" it can eventually cause a ply separation which will cause an out of round condition which will cause the tire to have a "bounce".
The proper way to repair a tire puncture is from the inside with a patch stem pulled through the puncture hole.
I wouldn't have guessed the heat could make a 3.5 year old tire look that bad. The rubber chunking off looks like the cheap hercules 8 year old snow tires I ran for 3 summers...
I guess you don't get much rain, but those tires would need some extra care to get around safely.
It seems you need to pick a new tire based on its resistance to aging from heat?
Right on!
I spent several years retreading truck tires, That is a casing separation.
Cut out the blister. It would be interesting to see what's underneath . I bet you will find Rusty belts.
Originally Posted By: expat
Right on!
I'm going to guess that the steel belt is in the way except at the tread edge. So Jack, if you do cut into it, start at the tread edge and cut horizontally into it - between thge eblts.
Oh , and rust inside is NOT a symptom as much as it is the result of the rubber peeling off the steel belt.
And, No, these are not typically adhesion failures. They typically start under the top belt NEAR the belt end, but within the matrix of rubber. It's a fatigue failure of the rubber.
Right on!
We would often see this if a truck was overloaded or had low tire pressure.
It was often thought that a small separation might start around a puncture to the belt depth (causing the belt wires to separate form the rubber). Water in the small separation might then be forced, under the tread, with every rotation, causing an ever larger separation.
We would normally see a lot of this after the first rain at the end of summer.
The tire looks indented and shaved down in the middle - I thought that was usually from over inflation?? Although the outer blocks aren't exactly in good shape either... I wouldn't think 36psi is nearly enough of a deviation to account for that kind of wear though.
The Insignia was a very weak tire near the bottom of Bridgestone's line up and supplied as the factory fit on the base Corolla for a number of years. I would not judge any tire manufacturer based on a product for such an application.
I hope Darris won't think I am picking on him - even though he is kind of new around these parts. It's nothing personal, just a cautionary note concerning the way many people think about things.
What I want to point out is that the photos are all of the bulged out area. You just can't judge what the rest of the tire looks like by looking at that area - and it is the undisturbed portion that ought to be looked at to make the sorts of assessments he made.
And I would also caution making an assessment of inflation pressure based on wear. As a tire designer, I could alter the wear by changing the shape of the belts - and sometimes we would deliberately change it to improve rolling resistance, knowing that we were hurting wear. In other words, do NOT assume that center wear is caused just be inflation pressure.
Capriracer, you are a great resource for the forum, I learn something from your posts often, but this one really surprised me....I had no idea that this was true!
As an example, with 50,000 miles on them, my Conti Extreme DWS in 235/45R17 are worn to the bars in the center, but still at 5-6/32 on the edge. I had run them at factory specified pressures (34 -38, depending on anticipated load) their entire life. I had assumed it was simply Volvo specifying too high of a pressure...now, I see that the issue is more complex...
