graphene please!
Which of its properties do you think are relevant to motor oil?
Originally Posted By: yvon_la
ya graphene is expensive ,but its properties are so uber that I highly doubt it will be ignored!
sidenote:any have ever had rotary engine?(aka wankel in the mazda or other car brand,wouldnt a graphene film be perfect for those troublesome leak prone engine?
I cannot list all the properties of graphene,the list is too long but it is very different from graphite (wich had troublesome problem like corrosion
Actually yes I did, a very rusty 1984 model that burned a lot of oil. It was fun to drive though. They didn't "leak" oil as such, it was apex seal wear that was the problem. Oil consumption was a secondary problem, the primary issue was loss of compression.
If graphene is added to motor oil would it bond to surfaces?
From what I've read with google searches no it doesn't. It's like Teflon from what I understand and doesn't work like mos2 in relation to "plating" moving parts
Actually yes I did, a very rusty 1984 model [Mazda Rotary] that burned a lot of oil. It was fun to drive though. They didn't "leak" oil as such, it was apex seal wear that was the problem. Oil consumption was a secondary problem, the primary issue was loss of compression.
Why not MoS2? It bonds to metal. It's available. I've never owned a Wankel engine, but problems with the apex seals are well known.
Well, actually I would if it had new apex and side seals, and I knew the compression was good.
Then again that particular car is now incorporated into a bunch of green bean cans, and even possibly my current cars
