Fastest MIR ever!
by parshisa
14 minutes 18 seconds ago
2003 Dodge Dakota 4.7 V8 5-speed manual 4X4
by oilpsi2high
26 minutes 10 seconds ago
Eagles are one and done..
by LeakySeals
34 minutes 14 seconds ago
Switching Oil viscosity giving Quicksilver a try
by ad244
Today at 01:54 PM
2015 Yaris oil recommendation
by BIMMA
Today at 01:29 PM
Can any one tell me who make's this air filter?
by rollinpete
Today at 01:17 PM
38 years ago today
by dnewton3
Today at 01:07 PM
PQIA - Havoline HM Synblend 5w-30
by wemay
Today at 12:44 PM
Any 2015 Corolla owners here - coolant change Q
by NissanMaxima
Today at 12:20 PM
Thoughts on 2007 Hyundai Azera for $2700
by 901Memphis
Today at 12:18 PM
run straight coolant
by slomo
Today at 11:43 AM
How much liquid is needed to hydrolock an engine?
by zorobabel
Today at 11:14 AM
Intake manifold bolts torque 11ft lb
by Ndx
Today at 10:55 AM
Orange can of death
by WyrTwister
Today at 10:42 AM
Weird Master Cylinder Behavior
by artbuc
Today at 10:42 AM
Police were called, I was shoplifting!
by expat
Today at 10:41 AM
Mobile CI-4+ in Cummins 5.9L
by MileHi
Today at 10:19 AM
How & what pistol do you carry concealed?
by callbay
Today at 10:13 AM
High Mileage Transmission Change
by toreytlow
Today at 10:13 AM
Jamison Guardian Ammo
by BlueOvalFitter
Today at 09:53 AM
toreytlow, KOlan, Tenorman, DMperfection101, WiseOne
64257 Registered Users
112 registered (4WD, 2010Civic, 901Memphis, 69Torino, 14Accent, 7 invisible), 1709 Guests and 95 Spiders online.
64257 Members
65 Forums
278546 Topics
Page 6 of 6 < 1 2 3 4 5 6
#4269255 - 12/08/16 04:32 AM Re: Used oil analisys on Renault Megane II Break 1.5 D [Re: Jetronic]
Esmolante Offline
Loc: Galiza
If you're right, then, UOA is useless to prevent it. frown
I'm not sure that in K9K engines it's possible to change shells under de car, demounting the oil sump. In many engines (my Vito, f.i) is necessary to demount all the timing cams, pistons and then, we arrive to the crankshat.
Kia Cee'd 1.6 CRDI
Fiat Ducato 2.3
Mercedes Vito 108D
Kawasaki ZX10R
Suzuki GSXR600
#4269507 - 12/08/16 11:51 AM Re: Used oil analisys on Renault Megane II Break 1.5 D [Re: JorgeMartins]
Jetronic Offline
Loc: down in the park
Not really.
Before the bearing spins, there will be repeated contact and wear from said bearing.
Bigger engines often have a (timing driven) balance shaft assembly, which sits in the sump. Small engines don't have these unless it's not a 4 cylinder.
AR Giulietta 2.0 JTDM-2 -- Total Quartz 9000 Energy 0w30
Hankook Ventus Prime 2 215/50R17 (front)
Pirelli P7 Cinturato 225/45R17 (rear)
#4281879 - 12/22/16 06:40 AM Re: Used oil analisys on Renault Megane II Break 1.5 D [Re: UltrafanUK]
JorgeMartins Offline
Loc: Portugal
Originally Posted By: UltrafanUK
Originally Posted By: JorgeMartins
Hi there.
Again, i've requested a 4th engine used oil anaisys and I need some help to interpretate it based in the topic domain.
The Potassium figure is interesting, although if it is from anti freeze the level is not high enough to be an issue at present.
The OCI was too long and resulted in the oil thickening, also the insolubles figures is near the limit, so I would reduce the OCI to 10K.
No real harm done, but 14K does seem too long!
Too thick an oil can slow down oil flow around the top end, so I'm not surprised the Al figure is a tad high.
Hi.
Sorry to respond so late.
Thanks for the review
what do you mean with "AI"?
Thanks again.
#4281881 - 12/22/16 06:43 AM Re: Used oil analisys on Renault Megane II Break 1.5 D [Re: Bobby_x]
Loc: Portugal
Originally Posted By: Bobby_x
Hi,
all your tested oils have add packs based mainly on Ca, P and Zn
There are some European mid-saps oils having strong dose of Boron, Moly or Magensium, maybe it's worth to try them if your engine goes better.
Elf Solaris FE 5W-30 - holding Renault 0720 approval, lot of Moly, some Boron and less Calcium
Mobil ESP 5w30 - high Boron, some Moly, less Calcium
Petronas Syntium 5000 RN 5W-30 - high Magnesium, less Calcium
based on analysis:
http://www.oil-club.ru/forum/topic/18416-5w-30-svezhie/
I'd stick to at least mid-saps oils not because of FAP, which in your case is missing, but rather to avoid deposits in the engine and turbo
Hi.
Thanks for the sugestion, i'll consider it.
#4281892 - 12/22/16 06:55 AM Re: Used oil analisys on Renault Megane II Break 1.5 D [Re: Esmolante]
Loc: Portugal
Originally Posted By: Esmolante
Bom dia, vizinho. smile
What I have heard about catastrophic engine failure in K9K is that some connecting rods' shells (capas de biela, penso que se chaman en português) lack of flap that inmovilize them. So, that shells roll and block the oil leads. Without lubrication, wear rate rockets, shells are destroyed and then the connecting rod, destroying the engine.
What I can't understand is Renault isn't able to determine what engines are affected. Renauld has (or should have) notice of what part has been used in which engine. It would be as easy as composing a list of engines with faulty shells and replace it.
In fact, I don't know even what incarnations of K9K are affected (o meu sogro tem o dci 68CV, andiven a pescudar e penso que ese motor não está afectado). Anyway, I think doing UOAs is an smart idea. As soon as you see copper and/or lead peaks in an analysis, change the shells ASAP. You can do an UOA each 2 OCI's (but I'm not sure how fast shells destroy once the problem appears).
Oil viscosity: 5W30 seems better for your bearing and 5W40 for cams and piston rings. With both, Iron is a little bit high. I recomend you don't go further of 10.000 km with OCIs.
BTW, several K9K have a big problem with fuel pump make by Delphi. Search for steel savings into the fuel filter and reduce interval to 30.000km maximum. Do some research if your car has that awful Delfi pump (Bosch VE doesn't have any problem).
Sugiro unha Super Bock preta como agradecimento. laugh Cheers2
Até logo!
Olá vizinho.
Yes it is exactly that problem.
Renault PT always denied the problem I even contacted Renault FR and no answer!!
I'm am doing 1 UOA by 1 OCI.
My idea is to make the OCI every 10.000 km but this time I let it through.
I have never heard about the fuel pump problem but I will now deepen this situation. What problems causes that failure?
Só bebo Sagres, mas posso oferecer uma Super Bock.
Abraço.
#4281894 - 12/22/16 06:57 AM Re: Used oil analisys on Renault Megane II Break 1.5 D [Re: Jetronic]
Loc: Portugal
Originally Posted By: Jetronic
If you spin a bearing and block the oil passage, failure is a matter of minutes... starts with knocking, but this possibly goes unheard on a diesel, and ends with a rod through the block probably all in the same drive...
Exactly.
#4399949 - 05/09/17 07:00 AM Re: Used oil analisys on Renault Megane II Break 1.5 D [Re: JorgeMartins]
Loc: Portugal
Hi there.
Again, i've requested a 5th engine used oil anaisys and I need some help to interpretate it based in the topic domain.
Edited by JorgeMartins (05/09/17 07:02 AM)
#4400114 - 05/09/17 10:57 AM Re: Used oil analisys on Renault Megane II Break 1.5 D [Re: JorgeMartins]
Jetronic Offline
Have the last 3 oil changes been Elf Evolution SXR?
These are good results, apparently the oil can last longer in use. No signs of imminent failure of either oil or engine.
#4400142 - 05/09/17 11:30 AM Re: Used oil analisys on Renault Megane II Break 1.5 D [Re: Jetronic]
Loc: Portugal
Yes, Elf Evolution SXR 5W40.
Thanks.
