Toro Vintage Snowblower... Craigslist Find
by Warstud
02/19/18 06:55 PM
Effects of using the wrong oil
by salesrep
02/19/18 06:52 PM
Anyone here own a Chevy Cruze diesel 6 speed?
by skyactiv
02/19/18 06:45 PM
Pick me an oil from my stash
by pda1122
02/19/18 06:35 PM
Washer/Dryer Recommendations
by coopns
02/19/18 06:31 PM
Moly lowers Timken OK load
by another Todd
02/19/18 06:13 PM
PennGrade oil
by Thunderbolt
02/19/18 06:11 PM
Anti seize or brake grease on brake pads
by pda1122
02/19/18 05:47 PM
Engine noise increases with mileage?
by dlundblad
02/19/18 05:00 PM
Where are the ANs?
by PeterPolyol
02/19/18 04:50 PM
No free speech Britain
by Pajero
02/19/18 04:21 PM
Anyone here still use AAP and AZ for their fluids
by M1Accord
02/19/18 03:42 PM
Dirty oil ?
by Camprunner
02/19/18 03:36 PM
Recluse Holsters
by bigj_16
02/19/18 02:48 PM
hearing radio frequencies....type of tinnitus ?
by Shannow
02/19/18 02:30 PM
Walnut blasting dyno results
by Tommiee
02/19/18 02:04 PM
Mobil1 0W40 European Car Formula.
by George7941
02/19/18 01:18 PM
Advance Auto Parts - Rock Auto
by WyrTwister
02/19/18 12:47 PM
Where to get the good WIX 51372
by Fordiesel69
02/19/18 12:35 PM
ABS and Traction lights on? 2015 Charger
by Blue_Goose
02/19/18 11:52 AM
Thunderbolt, ttang11, 2017Hatchback, dgoodhue, Canuckles
64237 Registered Users
142 registered (2015_PSD, 2cool, 2009Edge, 14Accent, 2002 Maxima SE, 2003f7, 14 invisible), 1771 Guests and 99 Spiders online.
64237 Members
65 Forums
278404 Topics
Page 2 of 6 < 1 2 3 4 5 6 >
#3407485 - 06/26/14 11:02 AM Re: Used oil analisys on Renault Megane II Break 1.5 D [Re: JorgeMartins]
yvon_la Offline
Loc: quebec canada
Mm!you arent using bio?then you must be a city driver !your ll need thinner oil .5w40 oil are great oil anytime but when cold.if you do a lot of start and stop city driving .might want to switch to a blend like a 10w30 for big truck .if money isnt an issue you could try shell rotella t6 0w40 or mobil delvac1 le5w30 (all the one i mentionned are all big truck oil).no it doesnt have to be exactly those,they re just a reference for comparision .
Truck driver
Nissan versa note s 2014 total classic 5w30(qc.ca) drivework oil filter
#3410574 - 06/30/14 06:06 AM Re: Used oil analisys on Renault Megane II Break 1.5 D [Re: Blasar]
JorgeMartins Offline
Loc: Portugal
Originally Posted By: Blasar
JorgeMartins,
As already said, besides the values of Fe, Al and Silicon, your UOA seems normal.
Try the OEM air filter, if you are using other brand, and shorten the OCI to see if the numbers go down a bit.
FWIW, I can confirm what was said about the directives being followed by the Portuguese branch of Renault, and I donīt take too serious what the auto magazines try to sell us, but thatīs another issue.
Regards.
Hi Blasar.
The air filter is almost new, and it's clean.
Thanks.
#3410575 - 06/30/14 06:08 AM Re: Used oil analisys on Renault Megane II Break 1.5 D [Re: yvon_la]
Loc: Portugal
Hi yvon_la,
60% city.
My car use Castrol Edge 5W40 it's the Renault recommended oil for this car.
Many thanks.
#3419158 - 07/09/14 05:37 AM Re: Used oil analisys on Renault Megane II Break 1.5 D [Re: JorgeMartins]
Blasar Offline
Loc: Portugal
If the air filter is OK and is the OEM recommended, and all the intake system is pristine, maybe shortening the OCI does do the trick, but is just a guess.
Regards.
Excuse my poor English.
#3419302 - 07/09/14 08:55 AM Re: Used oil analisys on Renault Megane II Break 1.5 D [Re: Blasar]
Loc: Portugal
Regards.
Hi Blasar
Can you please be more specific about:
"OEM recommended"
"shortening the OCI"
Thanks.
#3420976 - 07/10/14 04:48 PM Re: Used oil analisys on Renault Megane II Break 1.5 D [Re: JorgeMartins]
chrisri Offline
Loc: Rijeka, EU
Does yor car have DPF? If not i would use Selenia WR 5w40 in this Megane. It's one of the best common rail engine oil for cars without DPF. And shorten your OCI to 10 k km or 1 year if you are doing alot of short trips. And you really don't need 5w30 in your hot/ moderate climate.
99 FIAT Punto Sporting 16v MST 5w40
06 FIAT Stilo MW 1.9 Multijet SHU 5w40
07 Opel Vectra SW 1.9 CDTI 150 MST 5w40
#3421432 - 07/11/14 04:06 AM Re: Used oil analisys on Renault Megane II Break 1.5 D [Re: chrisri]
Loc: Portugal
Hi chrisri.
What is DPF?
My car uses Castrol Edge 5W40 not 5W30.
Thanks.
#3421490 - 07/11/14 07:15 AM Re: Used oil analisys on Renault Megane II Break 1.5 D [Re: JorgeMartins]
chrisri Offline
Loc: Rijeka, EU
Hi chrisri.
What is DPF?
Thanks. [/quote]
DPF= diesel particulate filter,an emission nonsense,but you probably don't have any in your Megane since you are using Edge 5w40. Some others recommended 5w30 oils and this is why i mention that grade.Stick with Castrol but keep your oil change interval under 10000 km.
#3424054 - 07/14/14 04:28 AM Re: Used oil analisys on Renault Megane II Break 1.5 D [Re: JorgeMartins]
Loc: Portugal
Hi chrisri.
Thanks.
#3424217 - 07/14/14 09:41 AM Re: Used oil analisys on Renault Megane II Break 1.5 D [Re: JorgeMartins]
yvon_la Offline
Loc: quebec canada
Diesel are usually bullet proof!check engine oil pump thread online,i dont know any diesel engine that need a big fix at 150k
Truck driver
#3424228 - 07/14/14 10:00 AM Re: Used oil analisys on Renault Megane II Break 1.5 D [Re: yvon_la]
Loc: Portugal
yvon_la,
You Know now, In Portugal Renault recommends changing the big end bearing on 1.5dci (Renault, Nissan and Dacia) between 100 and 150k!
If you google it, chectk on foruns or contact Renault stands it's easy to find.
#3424669 - 07/14/14 05:55 PM Re: Used oil analisys on Renault Megane II Break 1.5 D [Re: JorgeMartins]
yvon_la Offline
Loc: quebec canada
I aint saying the bearing isnt an issue ,but usually oil pressure is the culprit.side note stuff like twin cam and variable ....is fairly new on the diesel world wouldnt surprise me if pressure of oil need to be 5 or 10 psi higher then it used too
Truck driver
#3425194 - 07/15/14 05:51 AM Re: Used oil analisys on Renault Megane II Break 1.5 D [Re: JorgeMartins]
Loc: Portugal
yvon_la,
yes some times i've heard about oil pressure too, but is just another teorie like others, not confirmed.
Thanks.
#3588930 - 01/05/15 09:36 AM Re: Used oil analisys on Renault Megane II Break 1.5 D [Re: JorgeMartins]
Loc: Portugal
Hi there.
I've requested a second engine oil anaisys and I need some help to interpretate it based in the topic domain.
Renault Megane II Break 1.5 Dci, 105 hp from 2007. Diesel engine.
I change the oil at 15.000 Km intervals, and the oil i'm using is Castro Edge 5W30.
Many thanks.
#3598380 - 01/13/15 06:33 AM Re: Used oil analisys on Renault Megane II Break 1.5 D [Re: JorgeMartins]
Loc: Portugal
Hi there.
Anyone??!
