blackman777
Thread starter
Honda's first VCM engine (2004-07) worked just fine. How could they screw-up the redesign?
(ponder)
FTC stopped Slick 50 from making these claims: "Every time you cold start your car without Slick 50 protection, metal grinds against metal in your engine." ----- "With each turn of the ignition you do unseen damage, because at cold start-up most of the oil is down in the pan. But Slick 50's unique chemistry bonds to engine parts. It reduces wear up to 50% for 50,000 miles."
In fact, the FTC said, "most automobile engines are adequately protected from wear at start-up when they use motor oil as recommended in the owner's manual. Moreover, it is uncommon for engines to experience premature failure caused by wear, whether they have been treated with Slick 50 or not."
(ponder)
