Originally Posted By: Hokiefyd
I would use the stock size filter. That's a #7317 in Fram speak or #14610 in Purolator speak. Honda's A01 or A02 will both work.
Exactly ... all of those filters have about the same media area as filters used on 400+ HP V8 GM engines (ie, C5+ Vettes). You aren't going to gain anything by going bigger on this engine IMO.
I wouldn't even be thinking of grinding/trimming the engine block area around the filter mount to put larger filters on the engine. Just throw an XG7317 Ultra on it and be done.
