Which aftermarket oil filter do you use for 2013-2014 Honda Accord 4-cyl ?
Fram recommends TG7317 (D 2.7" x H 3.5") for newer Accord and TG3593A (D 3.0" x H 3.4") for 2002 and older Accord.
Wix recommends 57356(D 2.7” x H 3.4”) for all Accord.
HandA recommends 15400-PLM-A01 for all Accord. What are external dimensions, flow rate, by-pass pressure and gasket dimensions of PLM-A01 ?
According to online owner manual the location of the oil filter is at the bottom of the engine facing up, it looks like too long filter such as Wix 51347 (D 2.9" x H 4.8") may not be a good fit, because the bottom of the filter may be exposed to road debris ?
Also, is it a good idea to use cap wrench to remove/install the filter ? If you do what is cap wrench size and number of flutes ?
