My Tundra goes in on Tues for front diff rework. I believe it's new bearings, new diff, new axle; but same ring and pinion. When should I change the diff oil after this? 5k? 10k? I try to keep the miles to 10k/year on this. It's a shame actually, as I changed the diff oil last weekend and it goes in on tues... and has the Mobil 1 stuff drained out.
[Didn't learn about the TSB until afterwards, I thought the noise was another bad tire and was waiting for tire rotation time to confirm.]
I kinda need to change the oil again in the other parts, as I neglected to notice that it uses steel crush washers on the rear diff and aluminum on the front and TC... I mixed up the ones I got. I *think* if I work fast I can change the rear real fast w/o losing all the oil. I *think* if I do it w/in a year it's unlikely it would sieze. I think. [Might just buy a new drain bolt, and swap in the new one, so as to make it faster.]
