Originally Posted By: fordranger03
Wow, I didn't expect this many responses. I'll look a bit further into all of them. What's the deal with water from some pumps? This is the first I've heard of this. How do I eliminate water from getting into the tires?
When I had to use pumps at the gas stations, I'd squeeze trigger before securing it on the tire valve. You can see water spray initially and then clear.
