Camper shells compatible with short bed Silverado?
Northern Virginia
What other model camper shells are compatible with short bed (6-1/2') Silverado / Sierra?
e.g. would a Toyota Tundra camper shell fit?
I am trying to find a used one and want to expand my options.
A while ago I wanted a cap for my Tundra, so I started collecting measurements from the web. One problem you will run into is that nobody seems to make the rear of the cab perfectly vertical any more--they are all angled somehow. Which you might not care about.
I only collected data for the 6.5' beds. I found two sites, so some measurements conflict.
Chev:
'73-87 is 79.25" long and 72" wide, 23" tall.
'88-98 appears to be an inch shorter in length.
'99-05, 81.5" long, 70" wide front / 68" rear, 23" tall
'67-87, 80" long, 71" wide
'88-98, 80" long, 69.75" front, 67.76" rear
'01-06, 81.5" long, 71.5" front/ 68" rear
Dodge
'72-93, 79.25" long, 72" wide, 23" tall
'72-93 stepside too narrow at 63"
'94-01 is 80.25" long, 75" front/69" rear, 22" tall
'02-05 is 79.25" long, 72" wide and 23" tall
'72-93, 79" long, 71" wide
'94-01, 80" long, 71.5" front / 68" rear
'02-08 78.5" long, 71.5" front/68" rear
Tundra
'04-06, 78.25" long, 68" wide, 22" tall
'07+, 79.25" long, 71.25" front/69" rear, ?" tall
Ford
'97-03 is 80.25" long, 69" wide, 22" tall
'04-05 is 81" long, 72" front/69" rear
'64-72, 80" long, 73" wide
'97-03 80" long, 70.5" front / 69.25" rear.
'04-08 is 80.5" long, 71.75" front/68.5" rear
http://www.truckinamerica.com/toppers/BedSize.htm
Sometimes you can get mismatched colors to work. Beauty is in the eye of the beholder. That said, you can have fiberglass repainted.
Chev:
Dodge
Tundra
Ford
Nice little list, thanks. Going to print it for my Dad.
Originally Posted By: pacem
Another question. Would a different color camper shell look bad?
e.g. a white camper shell on a black truck?
I think that a black topper/lid would look fine on any color of truck, since you already have black tires, black plastic trim pieces, black plastic caps on the bumpers, etc.
