In several items I've read on the 'Net, many of which are over my head technically, I've seen the occasional suggestion that use of ethanol-charged gasoline could help with the tendency of DI engines to buildup deposits on their intake valves. Now as I understand DI, no gasoline "washes" the valves, unlike in port-injected engines. So I don't see how E10 gas can help with the deposit problem. Or am I getting this backwards?
Is there any accepted preventative for these deposits, other than frequent oil changes with a low-NOACK, carmaker-approved oil?
