Originally Posted By: BISCUT
I've had some trouble in applying RX in the past. Mind sharing how you apply? I get swirls and streaks I can see.
I apply Rain-X to the glass prior to washing the vehicle. Then, while the Rain-X is drying/hazing(which doesn't take but a minute), I vacuum the interior, clean the wheels/tires. THEN, I wash the car as normal.
If you want to apply the Rain-X w/o washing the vehicle, I like Traction's method:
Originally Posted By: Traction
I've found the trick to applying Rain x is wipe it on, and use a spray bottle, mist a little water on it. Wipe it with a mf towel and no steaks. Works great.
