Hi all, long time viewer of BITOG, and excited for my first post! After reading and studying the topic here and in other research papers/books, I'm curious which detergent formulation could be considered better either in PCMO/HDEO applications?
Many threads here that i've looked at seem to be inconclusive or highly speculative, and i'm hoping to find more factual info and more references i can learn from. For instance i've read an article from machinery lubrication, along with the Oronite research paper on the subject with their ending conclusion being: "Each of the evaluated detergent types has strengths and weaknesses. , and in order to optimize a lubricant’s performance, it may be best to use a well balanced mixture of more than one detergent type."
http://www.machinerylubrication.com/Read/354/reserve-alkalinity-oil
http://www.oil-lab.com/downloads/TBN-1.pdf
I understand that various oil manufacturer's will develop different formulations based off cost effectiveness, efficiency, etc. with all passing appropriate API and other governing bodies requirements, but would u say any one would be a better formulation as a detergent package? Such as a Cal/Mag blend over Calcium alone?
I've looked at VOA/UOA's and found that when diesel oils are concerned many use a blend: Delo, Delvac, SRT 5W40, SuperTech, Napa, Car Quest, etc.
http://www.pqiamerica.com/March2013PCMO/HDEO SUMMARYrev2.html
But when compared to syn PCMO's only Castrol Edge and Mobil 1 used the blend (in the oils tested of course)
http://www.pqiamerica.com/March2013PCMO/Marchsyntheticsallfinal.html
Following PCMO's that are a standard petroleum oil with all of them only using Calcium with negligible magnesium content.
http://www.pqiamerica.com/Feb2014/consolidated5w20ALL.html
I understand that magnesium tends to cost more, and that it's not as effective at combating all forms of acid like calcium, with the possibility that it crystallizes more easily possibly leading to increased wear, and that it tends to maintain a higher TBN since it my not neutralize as many acids, but can any of u shed any more light on the subject or have any recommendations of other books/articles i can gather more info from?
Sorry for the long post and thanks for any and all info/replies!
