Originally Posted By: rslifkin
On a 2000, the head probably cracked when it got hot (0331 head). Has it been losing coolant? If so, the bearings in the bottom end are probably shot if it's got low oil pressure, as the coolant has likely wiped them out.
If the oil isn't milky, no slime under the oil cap and it hasn't been losing coolant, then verify the pressure with a mech gauge and replace the oil pump if it's actually low (worn out oil pumps aren't uncommon on high mileage 4.0s).
This.
This.
