Originally Posted By: Dave Sherman
I'll be doing my first valve adjustment on the CR-V soon, and I have the procedures from Honda. The only thing I was wondering is they call out some Honda part number for some sealant to use where it meets the chain case. Would RTV or Permatex be suitable for that?
Also, more importantly, be aware that if you've never adjusted valves before, there is a good chance that you could get it wrong the fist time. Do you have to adjust them with cold or hot engine?
Make sure to get the right-size (metric) feeler and use the correct size. Obviously don't confuse inches and millimeters. Do not confuse between intake and exhaust valves either. What I do when I adjust my valves is that I adjust the screw until the feeler is completely tight and can't be pulled out. Then I loosen it just slightly enough so that I could pull the feeler out with some (but not too forceful) drag. It's easy to think/feel that there is a drag but the valve gap is actually too big. That's why I tighten it fully first. After you set the valve gap and tighten the locking nut, make sure to recheck the gap because it could change when tightening the locking but. Also, make sure to set the TDC correctly before adjusting the valves.
Good luck! It's a very nontrivial adjustment.
