Originally Posted By: stockrex
Oil consumption: this is NOT normal, I redline very often, and I never had oil consumption.
Toyota issued a TSB for excessive oil consumption. My mothers 2AZ-FE eats 2 quarts in 5K miles, which is apparently "within spec".
Toyota released T-SB-0094-11
"Some 2006 – 2011 model year vehicles equipped with the 2AZ-FE engine may exhibit engine oil consumption. The piston assembly has been changed to minimize oil consumption. Use the following repair procedure to address this condition."
YEAR(S) MODEL(S) ADDITIONAL INFORMATION
2007 – 2011 Camry HV, Engine(s): 2AZ, VDS(s): BB3EK, BB46K
2007 – 2009 Camry, Engine(s): 2AZ, VDS(s): BE46K
2009 Corolla, Engine(s): 2AZ, VDS(s): BE40E
2009 Matrix, Engine(s): 2AZ, VDS(s): GE40E, KE40E, LE40E
2006 – 2008 RAV4, Engine(s): 2AZ, VDS(s): BD31V, BD32V, BD33V, BD34V, BD35V, ZD31V, ZD32V, ZD33V, ZD34V, ZD35V
2007 – 2008 Solara, Engine(s): 2AZ, VDS(s): CE30P
Inspection Procedure
NOTE
In some cases, a P030# (cylinder # misfire detected) DTC may also be set as a result of oil consumption.
Perform an oil consumption test to determine the consumption rate.
1. Confirm the engine oil level is full.
2. Mark the oil dipstick to indicate the current level.
3. Replace the oil dipstick.
4. Mark the oil dipstick, oil drain plug, and oil fill cap to prevent/indicate tampering during the test.
HINT
Use tape, sealer, cable ties, or equivalent to mark the oil dipstick, oil drain plug, and oil fill cap.
5. Advise the customer to drive the vehicle normally for 1,200 miles and return for inspection.
6. Determine the quantity of oil that was consumed in 1,200 miles.
Was the oil level more than 1 quart low after 1,200 miles of normal driving?
YES — Go to the Repair Procedure.
NO — This TSB does NOT apply. Warranty guideline for acceptable oil consumption is 1 quart per 1,200 miles of operation. No warranty claim should be filed.
