NOACK volatility ratings
by Rat407
02/27/17 07:29 AM
Engine shots - 07 Accord @ 100k miles
by AccordK24
02/27/17 06:39 AM
Fender bender city
by CourierDriver
02/27/17 06:07 AM
Schaeffer's representatives
by FowVay
02/27/17 04:02 AM
TRADE: Valvoline 5w20 SM dino (Orange County, CA)
by zorobabel
02/27/17 12:43 AM
How do I identlfy an Exide battery?
by Chris142
02/26/17 11:48 PM
Has anyone replaced iPhone battery?
by maverickfhs
02/26/17 09:40 PM
Replace belt tensioner or just the pulley?
by rationull
02/26/17 09:11 PM
Renewing Black trim
by Eddie
02/26/17 09:08 PM
Anyone still use Durablend?
by car51
02/26/17 08:58 PM
Schaeffer's 9000 5w40 - '03 TDI top end pic
by Alex_V
02/26/17 08:22 PM
What's up with all the storms forming at night?
by motor_oil_madman
02/26/17 08:21 PM
Costco battery warranty
by Kool1
02/26/17 08:05 PM
Just did first oil change with microgreen filter
by FlyingTexan
02/26/17 07:41 PM
Differential oil Infiniti G37x
by chartkor
02/26/17 07:20 PM
10w40 oil Not ILSAC Approved?
by doolah02
02/26/17 07:06 PM
Triple A....worth it or not?
by crookedaxle
02/26/17 06:58 PM
Under valve cover shot
by Ben Boyle
02/26/17 06:21 PM
how raise the idle speed on a mower?
by edwardh1
02/26/17 06:04 PM
Switching from Synthetic to Dino
by beadvised
02/26/17 05:45 PM
jteck75, jviss, xsboredom, Taylorm, banjobilly
60661 Registered Users
76 registered (4WD, 86cutlass307, AEHaas, adamrc, Bandito440, 11 invisible), 1263 Guests and 12 Spiders online.
60661 Members
66 Forums
261623 Topics
#3309564 - 03/12/14 03:44 PM pt cruiser using some oil
ram_man Offline
Loc: southern mo
Our cruiser seems to be using some oil when the dealer did the oil change it was filled half way up the safe range and it almost 1800 miles it's used Down to the add line. So half a quart in that time. I'm not overly worried being a saturn owner I understand some cars just do it. However if there is a way to fix it im all for it. Is there anything that could be causing this? Any common issues on these engines that cause consumption? Thanks everyone.
2015 dodge dart se rallye package
1995 Dodge ram 1500 5.9l
2003 chrysler pt cruiser
#3309573 - 03/12/14 03:52 PM Re: pt cruiser using some oil [Re: ram_man]
Olas Offline
Loc: Manchester, England
Its either leaking oil or burning oil, try topping up with maxlife to see if that slows it down, if not, either fix it or pay someone else to!
smile
1982 VW Scirocco
1457cc
98 bhp
78000 miles
Redline fluids
Mann/Mahle filters
#3309580 - 03/12/14 03:57 PM Re: pt cruiser using some oil [Re: ram_man]
earlyre Online   sleepy
Loc: Lima, Ohio, USA
kind of... they have a slightly wonky PCV setup, that under the right conditions(WOT, Hard/Fast right turns, etc) can let liquid oil(not just vapors) out of the crankcase, and back to the intake.
very common for folks to add a catch can in the PCV line on Neons/PT's, esp if it's a Turbo.
Mine:
09 Mercury Sable : 5qts Edge 5w20,1/2qt each Edge & GTX 5w30, WIX 51516
Mine to Maintain:
03 Pontiac Vibe : 4.5qts Edge 5w30,Fram XG4967
#3309596 - 03/12/14 04:14 PM Re: pt cruiser using some oil [Re: earlyre]
ram_man Offline
Loc: southern mo
The pcv valve is different than most I've dealt with to.
I don't think there is anything serious wrong. But maybe a pcv ? Didn't some have a tsb for a thing under the valve cover I forget the name some type of baffle that caused oil usage
#3309628 - 03/12/14 04:44 PM Re: pt cruiser using some oil [Re: ram_man]
mrsilv04 Offline
Loc: Illinois
For some odd reason, if the dealer switched to a different brand of oil, an engine will use more on that first change.
Don't ask me to explain it, but I've seen this myself when I switch brands of oil.
Whatever you do... do NOT speed through the town of Gauley Bridge, WV.
#3309646 - 03/12/14 05:02 PM Re: pt cruiser using some oil [Re: ram_man]
tomcat27 Offline
Loc: Midwest
My 96 Sebring with the 2.4 has always used a little oil. Maybe a quart every 2000-3000 miles. It did it new. It does it now with
200,000 miles.
2015 Rogue, 2014 Sentra, 2001 Camry, 2005 Starcraft, 1998 Dodge B1500
1996 Sebring Jx, 1984 F150, 1970 Cougar, 2013 XT250, 2010 Vstar
#3309756 - 03/12/14 06:52 PM Re: pt cruiser using some oil [Re: ram_man]
gregk24 Offline
Loc: FL, USA
If its manageable just add oil when necessary. If it gets worse, start using a HM oil like Maxlife.
2012 Honda Accord EX-L K24z3
45,xxx miles
PPPP 0w20 / Fram Ultra
2014 VW Jetta SE 1.8T ea888
24,xxx miles
Castrol Edge 0w40 / OEM filter
#3311149 - 03/13/14 09:40 PM Re: pt cruiser using some oil [Re: ram_man]
artificialist Offline
Loc: Florida
I help a friend with a 2004 Chrysler PT Cruiser, and his car always consumed oil. I replaced the PCV valve, and used 10w40 synthetic oil, and it made no difference.
That is so irritating! Many engines didn't consume oil years before this car was built.
2010 Lancer Ralliart Sportback
#3311540 - 03/14/14 09:21 AM Re: pt cruiser using some oil [Re: ram_man]
KitaCam Offline
Loc: SunnySouthFlorida
Why only half-way to F....? Why not all the way to F....?
1800 for a half-qt isn't bad at all...more than ideal, yes, but 3600 for a full quart might be just fine, depending on use and mileage on the car...
Edited by KitaCam (03/14/14 09:22 AM)
Kitacam is an 05 Camry LE/I4/MT; latest OC: 2/17 @ 142,300....PP 5w-30 with Toyo filter
#3312029 - 03/14/14 05:03 PM Re: pt cruiser using some oil [Re: ram_man]
ram_man Offline
Loc: southern mo
The pcv was less than stellar so I replaced it also I forgot the dealer replaced the oil pressure switch. They may have lost some oil doing that job.
