Originally Posted By: JTK
Originally Posted By: Kuato
Originally Posted By: Hollow
Check
www.cars101.com for all the specs about interior space and whatnot.
That's good information right there, but I've found that manufacturer's measurements are not consistent between brands...one make's 39" head room is another brand's 41", and usually don't take sunroof into consideration.
I haven't compared interior dimension specs side by side between the 2012 Legacy I had and my new 2014 Crosstrek, but I know on my Legacy, if I adjusted the driver's seat height up to a height that was marginally comfortable for me, my head just about brushed the headliner. I'd have to just about curl into a ball when falling into the drivers seat to not bang my head on the roof line with the seat like this as well (getting into the car). The front pass seat on the Leggy was silly low too, and not adjustable height wise.
Flip side of this is the Crosstrek seems to have a bit more room from floor to roof. I can comfortably adjust the seat height up and not whack my brain bucket. Obviously there's a bit less width and length between the XV-C and the Leggy.
That's odd. I'm only 5'11" but I don't have any issues with my Legacy being too low at all. I have probably a fist between my head and the roof when I'm driving. I'm interested in how you had the seat positioned. Did you have the seat up as high as it would go?
I have my seat adjusted basically where my wrists can sit flat on the top of the wheel and with my butt pushed into the back of the seat and my foot on the dead pedal my leg still has a slight bend.
