- Joined
- Nov 29, 2009
- Messages
- 7,217
Is it ok to cut through a couple 16 gauge finish nails with a table saw? I already did with my miter saw and it didn't do anything. I forgot to take the nails out the first time. (brain [censored]) There are two nails left in the board that I can't pull out. They are only a little bit larger in diameter than staples so I was curious as it even matter since I didn't even feel anything when I cut them with the miter saw unintentionally. My question is does it damage the blade? The carbide teeth are much harder then the nails so I think an occasional nail this size is ok Right?
