Couldn't dry gas be used to deal with phase separation when using gas with dreaded ethanol? Yet on the other hand I read here that dry gas is superfluous because ethanol does the same thing as dry gas. So how can dry gas (an alcohol) work in real gas, but e10 (an alcohol) is problematic from the start? BTW, I don't buy into the conspiracy-hysteria that ethanol is bad...I did have a lawnmower carb gum up, but this was in the pre-ethanol days.
