2012 Honda Accord V6 M1 0w20 5,000 miles
Don't know what the argument is all about, but pictures don't lie. What I don't get, the older pictures, the oil looked fried. But with VCM engaged, wouldn't the engine run cooler? As far as oil test goes, I'd think you'd see an upsurp in fuel dilution. When I do get a new honda with VCM, after reading this, I'd probably stick with a synthetic, but maybe not the M1 EP line, probably the "regular" synthetic stuff and change out at no more than 5K. Good to see Honda has windage trays in their oil sumps.
No, with one bank doing all the work, that bank apparently gets extremely hot. And it is the rear bank at that, the one with the least airflow over it.
Airflow over the engine block means little to the internal temp on most any vehicle. Likely has little to do with this particular engine's issues.
As always, it is worthwhile to note that Honda made a ton of these, and they don't all break down. Any mfgr that has big production numbers will have some rate of failure, it's very tricky to figure out the exact reason involved. Note that GM engineers told me face to face that they had a lot of trouble keeping their AFM engines HOT ENOUGH at highway speeds.
And anything I've had apart in the last ten years has a windage tray in it. You should see the beautiful welded up aluminum pan on the SRT with baffles and trays galore...
Additionally there were some part number changes for the heads on at least some vehicles I've not investigated what the changes were.
If someone could figure out what the actual UOA indicator is you'd probably be a bona fide Honda V6 hero, I suspect there that at least a consumer UOA isn't going to pick it up (at least not in time).
So that leaves us with other data.
Also unless you value your time at zero you have to "pay" yourself something in an ROI equation.
AFAIK There are two versions of VCM that Honda use/d on the 3.5 iVTEC the first generation that only shut the rear off and ran on the front only a lot of the time.
On the 08 and later they used the VCM II that did that but also turned on one cyl on the rear bank on and turned one off on the front bank making a staggered V4.
While deposits were a little better controlled the system is more complicated and had the oil consumption issue also.
IMHO there is no such thing as ROI with less expensive oils or longer OCI with these engines. A little neglect and someone is paying the dealer or someone like me to clean it, rebuild it, or replace it if they are unfortunate enough to be out of warranty.
There are short life PCV issues also that were discussed in my old thread.
Even in warranty people like one poster here who i had a lot of email contact with had to go to war with Honda to get a partial warranty fix for this issue and IIRC he had dealer service and OLM OCI.
ok so Dave says that this engine MAY not destroy itself on Dino. basically Chris your decision to use synthetic based on other people's engines failing on Dino is a stupid decision....??
What you should have done is run really short OCI's on $13 a gallon Dino meanwhile getting UOA'$ everytime. extend these UOa'$ until the wear is alarming.
THEN and only then you will actually know how far Dino can go in your engine. not only will this cost significantly more then using synthetic at 5k OCI's, which has been shown to not harm the engine, but it will potentially damage your engine as Trac has said the engine will abruptly go into limp mode not some gradual red flag on a uoa
but hey at least you will have proof that appeases Lord dave
unless Dave is saying you should guinea pig your engine and cross your fingers that honda saves your bacon
Yes thanks is due to Chris for posting and sharing useful information for all.
Originally Posted By: Trav
Thats the point they stop running on all cylinders. The day before that engine was running fine on all 6, it fell into eco mode and wouldn't come out of it.
My question is how would a UOA indicate this?
This is how it looked after cleaning, it runs great and staying clean on 5K synthetic OCI.
Thanks Trav for posting these pictures when "clean".
The older 3.5 iVTEC ones ran on 6 or 3 thats what causes the sludge/deposit/varnish issues.
The 08 IIRC and later had ring problems.
This is from an 05 with verified 7500 mi OCI with synthetic.
...The rear head with the VCM mechanism, it doesn't get as hot but varnish sticks everything.
...The valve that operates the VCM, oil pressure controlled and stuck with varnish.
Looking at these pictures at 7500 mi OCI with synthetic, so if one wants to use a Dino in the V6 VCM engine, is a 3000 mi OCI still going to produce the sludge and varnish problems ?
Then what is the maximum OCI when using a dino in the V6 VCM Hondas ?
Important - do we consider only Grp IV & V synthetics as synthetics for the V6 VCM Hondas, or will Grp III synthetics provide equally clean results during the 5K oci your have managed so far?
Originally Posted By: Chris B.
Originally Posted By: dnewton3
How does the OP know, for sure, that 5k miles isn't too far, even for M1? How does anyone protect an investment, if zero markers are defined and met? You either know, or guess; there is no in-between.
So the OP likes his M1; fine by me. But don't claim it's doing a great job, when you cannot define what that means relative to the concern you have. If it's sludge you fear, how does this UOA show it's being kept at bay? If M1 is doing such a great job, then show me the marker that convinces one of that fact.
Like I said before and it is a fact that these engines don't do well on conventional oil going by the MM because it takes 7,000 miles at a minimum for the MM to hit 15%. The oil sludges by then and starts the build up. This is not my opinion and is well documented. My UOA shows steady wear trending down and low insolubles. I have a scope and can see pretty deep through the fill hole and it is spotless in this engine with no sign of sludge or oil problems. So yes, M1 is doing a good job and this is fact...
Some where between 5k and 7k is where this engine starts to have problems based on what owners are reporting.
So then the marker for using a synthetic in these V6 VCM honda engines is somewhere between 5000 and 7000 miles?
Or who would want to risk their engine to ascertain exactly when does a Dino "start failing" for this honda ? !!!
This engine was run on a Grp III from 2005 till it stopped but that was 9 years ago, oils have improved a lot since then.
Mobil 1 0w20, 0w30, 0w40, 5w30 ESP, PU 5w20, PU 5w30 all have done a great job at keeping them clean. One has gone over another 100K since cleaning and it didn't make it much past 80K originally and its staying clean.
I cant say what other brands will do or wont do i haven't tried them but i understand DNewtons point. Under normal circumstances these are a very long life oils and draining them out a 5K would be a real waste but IMHO not on these particular engines and a couple of others.
Just from my own observations that front head runs hot, very hot! Honda changed it in 08 to add another cyl in the mix on the other bank and shut one off so they knew something was afoul IMO.
The other thing is, when the front cylinder begins to cook the tiny PCV gets clogged as does the valve covers internal passages and this just makes things worse.
The non VCM Honda 3.5 is a very good engine, smooth and powerful for a V6 with a nice power curve but these are a nightmare, IMO they ruined this great little engine then charged a premium for it, all for a of a couple of MPG.
What little was saved on fuel was eaten by shorter OCI, a ruined engine or a massive and expensive cleaning job. Thats called negative return on investment!
Valve cover front cylinder.
Location of PCV.
Tiny internally vented PCV valve.
Trav- Can the system that shuts the cylinders down in the older Honda engines be deactivated so it can run on all 6 cylinders all the time? It is pictures like these that keep me scratching my head about OLM's and these systems that deactivate cylinders in an attempt to save gas. I realize they're not all bad, in fact some are quite good. But I bet the owners of these Honda vehicles thought they were problem free when they bought them too.
What sucks it many of these people found out when it was just a little too late.
No the VCM cannot be turned off and run normally, you get an oil pressure light and limp home mode albeit on all 6 cyl. People have been trying everything from unplugging sensors and solenoids, etc but to no avail.
Thanks- I thought so. Too bad a simple re-flash can't turn it off.
Oh yes totally agree with Dave on his heated honest argument of 5K oci on a synthetic being a waste.... but when it comes to such troublesome engines, unless/until a mechanical solution is discovered or someone has done a detailed study to exactly calculate the precise maximum miles of "safe oci" for these (and other similarly troubled engine designs), it is safest to go with your current findings Trav.
Have you tried this, Trav?
http://www.odyclub.com/forums/52-2005-20...html#post730631
"1. OK, I looked and found for 2007 Odyssey EXL with VCM, the PN for the OPS is 37260-PZA-003.
It has bolt thread of M10 x 1.25 (see pic below).
2. Go to a hardware store and buy a "dummy" bolt M10 x 1.25 x 10 mm.
Check your OPS to be sure you need a bolt length of 10 mm.
3. Remove the OPS, keep the O-ring (washer).
4. Install the dummy bolt + O-ring (washer) and tighten it to spec.
This effectively seals the OPS hole so oil does not squirt out!
5. Now: re-attach the OPS to the connector (3-prong).
Cap the end with tape/zip tie to avoid dirt from entering the OPS.
By leaving the OPS attached to the wiring, this simulates an "Engine OFF" situation, which still sends some "voltage signal" to the PCM.
This way the PCM thinks:
a. The circuit is OK (i.e. no breach of the circuit)
b. "Sees" this as "not enough engine oil pressure" and
c. Therefore will not activate the VCM.
Hey this mod only costs $1 (the price of the "dummy" bolt)!"
Yes, years ago and it doesn't work it goes into limp mode. I have been working on something that should disable it completely but its not a priority just something i mess with when i feel like it.
Mr. Newton is adept in critical thinking and should be acknowledged, if not applauded, for his efforts to point out the lack of it in others. It's hard to argue with any of his points. We should remember that Bitog (and many other sites, for that matter) is intended primarily to be informational and there is a wide variety of people with a similarly wide variety of reasons for participating on this website. My personal opinion is there is very much a lack of critical thinking in general and good for him/her who is able to do it, as it will be of great benefit to them in life. It's not like they teach it much in public schools. That being said, the tone of someone's message matters as well if your intent is to educate. Education is a process and not a one time blunt force trauma to drive home a point. If Mr. Newton would accept more of a 'mentor' posture, his message would likely be received better and his desire to improve the level of discussion on Bitog would be more likely to happen. Are there a lot of people that participate on Bitog that post a lot of meaningless stuff and unsubstantiated postulations? Of course. As is the case pretty much anywhere. There are several good examples of mentors on Bitog. Doug Hillary is one. I know there are several others, but Mr. Hillary is one that immediately jumps to mind because he is consistent in his willingness to share his knowledge and experiences, and his temperament.
Just sayin' --------
Well said. Other mentors are CATERHAM, Tom NJ, Molecule, GARAK to name a few. I've learned a huge amount from Mr. Newton. He's saved me a lot of money going forward for which I'm grateful.
DN sometimes really gets his teeth into a UOA thread and this was one such thread.
The OP's point is that this engine is known through observation and experience to survive just fine on 5K synthetic OCIs.
DN's point was that we haven't identified the markers for the condemnation limits of any oil in use in this engine, so we're really just dealing in supposition.
The M1 might be done at 5K, but it might be useable for much longer than that.
Without an identified marker to use in establishing a condemnation point, we don't know.
I think he also meant to impart that if the engine is fine on 5K drains of M1, then it would also be fine on shorter drains of conventional oil.
Since we don't have any information as to what we should establish as a marker for condemnation, once again, we don't know.
If I were the OP, I'd probably continue with 5K OCIs on synthetic, since this has been shown to work, although with the information we have, we don't know why it works nor what marker in a UOA would indicate that it wasn't working.
Dave does sometimes get a little carried away in these threads, but his message is that we should be making oil use and OCI decisions based upon quanitifiable factors, not assumptions.
The OP rightly responds that this type of data development is well beyond the practical abilities of any individual owner, particularly if he has to bet his engine to get that data.
I think you give him far too much credit. I think of this guy when reading his posts......except without any people skills whatsoever.
