If you have a car equipped with winter tires and ABS, which braking technique will give you the shortest braking distance on ice:
1. Stomp on the pedal, and let ABS do all the work?
2. Push lightly on the brake pedal until ABS comes on, then back off slightly until ABS disengages?
3. Push lightly on the brake pedal, but do not allow ABS to activate?
