I have a 6yr old Nordic track treadmill. For the first few years that I owned it I never really used it that much. But up until recently I finally got back into a work out regiment. When I purchased the unit it came with several years of in home maintenance service and check up which included lubricating the belt. That's expired and It hasn't seen any service in awhile and I felt under the belt and it wasn't very lubricated anymore. So I ordered a lube kit from the manufacturer which consisted of (3) 5oz packets of silicon lube and very vague instructions. It told me to loosen the belt from each corner then spread the lube in a zig zag pattern on each side. Pull the belt until the portion that was under the unit is now on top of the deck and repeat the process, then feel over the belt to make sure the lube is coming into contact...Now I'm not sure if I should have used one packet for the whole thing or two. The customer service rep at NordicTrack said between 1-2 packets would be needed even though they sent me 3. After applying a packet to each side and letting the machine run on low for a min, the belt feels like its sticking even more than before to the deck and I can hear a sticky crackling sound. Is it possible to over lube these things, and what should I do?
Thanks
Thanks
