2012 Honda Accord V6 M1 0w20 5,000 miles
Originally Posted By: DuckRyder
What is the usage? Longterm steady state driving is where the VCM comes into play and starts creating problems.
That's exactly what I was wondering.
I wonder if the OLM algorithm has been updated for VCM.
Oil is cheap so "better" in terms of wear protection. Normally I agree that 5,000 on full Syn is a waste of money but not on the VCM V6. It is well documented that this engine is very hard on oil and it degrades fast.
Ah, yes, the old "cheap insurance" defense. Well known in the BITOG Court of Lubes ...
Please show me the "well documented" evidence that proves you need syn. So the engine may be "hard" on oil; so what? How does that translate into actual wear and ROI? Show me data that undeniably details how, in 5k miles, there is a statistical difference in wear outside "normal" sigma deviation between your choice of lube and a decent conventional oil.
Spend any time on Honda Forums and the Folks following the MM using conventional oil are having problems. It is all over the place with pictures and UOA's showing trashed oil and engines. The VCM feature is what is being blamed for this. I barley had time to post my UOA so since you're from Missouri you can go search for it yourself. I'll spend a whopping $22 two or three times a year on full syn and keep my $30,000 car well protected.
Directing me to other websites, also full of mythology and rhetoric, isnt' exactly the "proof" I was seeking. I still wait for true documented evidence and not scare tatics resounded by other uninformed folks. Maybe it's good enough for you, but I set a higher standard for my level of "proof". I would agree there are things that are "well documented" on those sites. Unfortunately it's not hard data with objective review, but rather subjective conjecture and regurgitation of opinion.
I see nothing in UOA data to indicate your selection of lube did anything outstanding. Macro analysis leads to the conclusion, even for your specific engine family, that syns at 5k miles don't pay for themselves. Read my "normalcy" article. Then show me, with real tangible data including your own UOAs, where your point of ROI is at, please. Can you please tell me the five top markers of wear, what the averages are for those criteria, what sigma deviation is exhibited by those criteria, and what condemation levels you have set for those markers, relative to your specific engine family, and how your specific engine compares/contrasts to those parameters?
Maybe you're right; maybe you "need" syns at 5k miles. But I have yet to see real world proof of such claim. You have done ZERO to prove it, other than make wide-ranging claims and point to other hysterical folks who substantiate your own personal viewpoint.
BTW - What makes you think I'm in MO? I live near Indy ... not that it matters ...
See 2 posts below yours quoted above. These folks having VCM problems are all over the forums. They are not making up this stuff for fun. It is a real problem with this engine and dino oil going by the MM.
Anecdotal blathering is not evidence nor data that can be understood statistically.
Show me how you (or any other Honda VCM owner) have determined safely and statistically that 5k miles is the correct mileage limit, and how you attribute that limit directly to the use of synthetic, please. How do you know 5k miles isn't "too far" as well? Or not far enough? Why 5k miles? Are you 100% sure that 5k miles isn't too much? Perhaps you should consider every 3k miles or 3 months; you know, like the good ol' days. You can double-down on the "extra cheap insurance".
Your data suggests nothing substantial came for your effort except gross waste, despite what anyone tells you to comfort your predisposed lube bigotry. I think it's clear what your want, and there's nothing wrong with that, for you. But some of us actually use data and facts to make reasoned, rational decisions. For us, there's more to an OCI then just guessing.
If you're going to dump M1 every 5k miles, then why even bother with the UOAs? If you started to have a problem, would you even know how to distinguish it in the UOA, versus standard deviation shifts? Right now, this is telling you that M1 did nothing special, and yet you continue to ignore the very data you paid for. So why is it you would have any faith in the UOA should it indicate something were wrong? You don't seem to trust it to be right; why trust it if something were askew? The UOA is telling you that you wasted money, but your emotion is telling you otherwise.
Again - what five markers are you looking for, what averages do you believe to be sound, what deviation is typical, and how are you setting condemnation limits? If you are not addressing these, you're just guessing your way through the entire thing. And of these "problems" you're trying to avoid, can you definitively describe the issues, and how they are cause by oil use and selection? Is there a limit where a conventional lube would be OK? What is the upper end to the use of syns? What symptoms manifest that indicate a problem is present?
You run M1 for 5k miles; I presume you have no issues to date so far. But that's just correlation and nothing more. You have not convinced me that your plan is attributable to safe operation. Let's expound on your logic here:
1) you use syn for 5k miles
2) you have no issues so far
3) you presume your engine is safe because of your actions
I can do that too ...
1) we have three outdoor cats at home
2) we have no wild bears roaming in central Indiana
3) I presume the cats are keeping the bears away
Maybe I should get a few more cats, just for cheap insurance ...
Don't confuse correlation with causation, sir. You have not shown me any proof that you have any data to use for rational decisions about your OCI or lube selection.
Whether you like it or not, you're not only wasting money on the lube, but also on the information you paid to ignore. Maybe that is your idea of "cheap insurance", but where I come from, it's called massive waste.
It's clear to me you have no interest in using the products you purchase as anything other than toys. Fine by me. I wish you the best.
I know the 3.5 iVTEC engines pretty well, i may have been one of the first ones to actually have one of these engines apart because of this issue and posted pictures, lots of them right here on BITOG and took some serious flack from the Honda fan club for it too.
I know this particular engine from new and it had verifiable OCI with gp III synthetic and deposited up so badly it stopped running on 3 cylinders.
This engine will not survive on 5K dino oil changes thats not an opinion. I have proven it on a real live engine.
UOA's are just snap shots in time and of little value when it comes to something like this, it will not show up on a UOA. When this issue arises it does it today and with no warning.
I have done more than a dozen of these and 5k on synthetic keeps them alive and clean for the rest of their lives, one i did has gone over 80K since tear down on it which is more than it had originally.
Could it go more or less? I know 7500 isnt doing so well and 5K does keep them clean long term so thats as close to it as i can come to putting a number one it.
5,000 miles on conventional has proven to be a bad match for this engine. As I have said before and have posted, this engine sludges and had early failures using the MM on dino oil. In many cases at 7,500 miles on syn, this engine has problems. At 5,000 miles on syn there has been no reports of problems.
Now none of this was done in a "lab setting" backed by controlled tests that take years and costs millions of dollars to conduct. It was determined by people like me and other forum members real world findings on what is really working in these engines better then what the factory MM recommends.
Tracking wear trends with UOA's can help when you do end up with a problem. I have on a couple different accounts, identified engine problems and fixed them before they became a bigger problem. The UOA's more then paid for themselves in these cases so not really wasting money here. Not many on here are scientists or tribologists and this is just a hobby for most on here so are we all wasting money? There is a lot to be learned from everyone posting their findings and the VCM engines needing short Syn OCI's is one of them. Why don't you PROOVE I'm wrong??? You can't just as I can't answer all you questions so don't even try.
Your cat scenario is your logic not mine and it quite silly. I know for a fact my engine is well protected because the UOA shows low wear and a clean report based on all reports on this engine. All the "proof and data" you want and keep asking for is spread out on the internet. It is not in the form you want. It is in the real world findings of people like Trav and the countless Honda V6 owners who talk and share "data" about what they are finding in every day use.
You are the one who is getting "emotional" Sir. Worrying about "massive waste" and getting all bent out of shape over changing M1 early LOL! I just posted a UOA to share with the forum, I'm done talking to you. You remind me of the type of person who is super book smart but doesn't have enough common sense to figure out how to hold the door open for a pretty girl or how to properly tie their shoes. The rest of us can keep swapping UOA's and figuring out how to keep our engines protected and running better.....
I just got done working a 16 hour day to help pay for all the free loaders in this country so forgive my grammar and punctuation. LOL! Good nite all.
First, thank you for sharing input from your real experiences
Now are you saying the Grp III oils have failed these engines on the 5K oci routine given by the MM?
If yes then what are the Synthetic Oils you will recommend for these Honda engines at the 5K OCI routine ?
If it were me i would go with a low deposit oil like Castrol Edge, or a GTL base oil like Pennzoil Ultra, which scores well in the deposit test too.
On page 7 if you havent seen it.
http://www.amsoil.com/lit/g3115.pdf
You guys still don't get it ... Let me simplify it in this manner with these questions:
What does a UOA show you that you can use as a marker to see when the issue in that engine family arises? Do you see a marked increase in wear metals? A huge shift in viscosity? What is it that the UOA gives you as a clue to know the probelm is afoot?
- If your answer is wear metals, then what shift in which elements are you looking for, past the standard deviation? At what point do you see a delineation in performance between conventional and synthetic lubes? Or, are wear metals not an indicator at all? It is not unheard of that wear metals may not indicate the onset of the problem (example to follow later ...)
- If your answer is vis, then what value is the tell-tale sign? Again, what value is the tipping-point? How does that contrast between the two choices (dino and syn) in macro data?
- Your individual UOA may or may not shot the onset of the sludge problem. Even if it does, it's too late by then. You're already into the problem if you count on your unique UOA to alert you. Visual checks (peeking under the valve cover) may do so, but I cannot assure you of that.
This is topically no different than the discussion I had a year ago about the coked-piston issue in Saturn SL2 engines. And believe it or not, there was a marker that could indicate the onset of the problem; it was oil consumption. Not wear, not vis, not insolubles, not FP. It was top-off fluid! And that information came from macro UOA data. While individual UOAs would not show immediate onset, the mass population data allowed clear delineation of the duration of the OCI where the problem began, and grew. DATA has value, even if it's not yours! And the data seemed indiscriminatory as well; age, brand, grade did not matter. And it was the same story there, too; the OP chose to use PU for 5k miles, but had ZERO idea of why he was doing it, other than his presumption of "cleaning" ability of the lube. He had zero data and no basis for any conclusion, until the marker was discovered in the macro data. And, because the data is predicated heavily on dino, he still has nothing but presumptive thought as to how the syn will react in regard to duration of exposure. So little syn data was there that the marker was not present. In short, he guessed that it would be OK, but had no proof that is was safe. If he was wrong, he too would fall victim.
If you all can get past your sensitive emotional reactions and read my INTENT here, you'll understand. There is good value in macro data; you can learn from OTHERS rather than having to experience the issue first-hand.
What I am pointing out is that here in this thread the OP has no idea what the markers are, or what condemnation points would be prudent based upon macro data. This is why I said he's wasting money; he is swaggin' a guess based upon correlation and not causation. He's being influenced by rhetoric rather than adjusting actions based upon facts. He is using the UOA as a toy rather than a tool. My cat analogy has merit; it illustrates the flawed assumption of presence of an attribute, relative to the exclusion of another. He uses syns; he sees no sludge at 5k miles (yet). That is coincidence and nothing more, as far as proof goes. One or two UOAs with syn in his application is meaningless. If he had 30 successive in a row, and evidence that sludge was not present, then I'd agree that micro data proved his point at that duration. But he does not have that; he has ZERO basis for mirco data conclusions. 5k miles is anecdotal at this point; he has no marker to point to (other than coincidence) that his lube and OCI are "right". He has stumbled upon correlation, not discovered causation.
If you said to me ...
"Dave - the marker is wear; there is a 63% elevation of Fe and Pb at 6.2k miles, with a confidence of .94, when using conventional lubes, but the marker can be shifted to 28% using syns" then I'd have to say you have an identifier. Or, if you said "Mr. Newton - the onset of sludge is predicated by a significant shift of oxidation and nitration outside the 3rd sigma, 47% of the time using conventional fluids at 4.9k miles, but syns delay this onset by one whole magnitude of exposure resultant of the same effect", then I'd have to agree you've found it. But nope - you show me nothing so far to convince me you understand what the markers may be, or how to quantify them. Rather, you rely on anecdotal gibberish and hype. You see some folks have success at some exposure, and you presume it to be gospel. Did it ever occur to you that some folks use syns in your application, and still get sludge? And some use dino, and don't get sludge?
If UOA micro data can show the onset of the problem, and you can indentify it, then don't hold back, because you can be the savior for the Honda faithful. If UOA micro data cannot define the onset, then why are you paying for the UOAs? You seem to infer that the UOA data in this thread is evidence of your choice being a good one, but then what is it you point to in assurance of the claim, because statistically the wear is well within normal response? You cannot have it both ways ChrisB. You cannot say the data shows this is a good choice, but then ignore the fact that the data shows no distinction between your syn and a typical dino oil. So, it the UOA data the basis of your markers, or not? Which is it?
It is my assessment that you have nothing to go on but your own supposition, backed up by other folks patting you on the back who also blindly follow the cattle trail.
You all would do well to read the "normalcy" article and internalize it.
Just because you all don't like my frank, stark assessment, does not mean I'm wrong here. Rude? Perhaps. Incorrect? Nope. Perhaps you find me offensive, brash and arrogant; maybe I am those things. But I find it irritating when folks mistakenly and carelessly apply incorrect conclusions. That's not the basis of the website's purpose. BITOG is a great place to share data and experiments, and to challenge others to prove their position. We can learn from each other. It was not created to be a sounding board for hap-hazard opinions and whimsical conclusions, backed up by other self-congratulatory lube bigots.
Contrary to popular opinion, I don't hate synthetics. I actually use them in some of my applications. But I don't profess them to be a one-size-fits-all answer. Nor do I use them blindly, because marketing and buddies tell me to. I do abhor waste and misinformation.
I conclude by offering a sincere public apology for those I hurt emotinally; that is not my purpose or intent. But some of you need some tough love, whether you recognize it or not. No one promised you an easy time of it when you post a UOA; that's not in the site rules. We are expected to treat and respect each other as adults, but that does not infer we have to coddle or agree with each other. If you set out public info, then be prepared to back it up. I am sorry if I offended ChrisB or others, but I am not sorry for speaking the truth about the use and misuse of UOA data, nor the wreckless conclusions thereof made.
Just read that amsoil link...kind of hard to buy into something published by a manufacturer that is also selling its wares. Guess my 06 Accord that I sold at 202K and still on the road (it was time for the dreaded timing belt change AND the AT was starting to show signs of failure again) would not have made it that far with 12K OCI with M1 EP. REALLY surprised to read into the VCM Honda problems. Just about all Honda problems have come to light from other Honda owners and then Honda finally addressed them when it becomes crisis management. But I will say, they will at least address them. Look into Ford's blowing spark plug issue....Ford won't even acknowledge such a problem exist....google Ford blowing spark plugs and just look.
I don't think we have any data showing anything about it quite frankly. At least not that has been gleaned from UOA's. Somebody is certainly welcome to prove me wrong though.
As does about 95% of this site
(and yes, I just made that statistic up)
I'm getting the impression that the UOA's on this engine leave us with a lot more questions than answers......
LOL!! Welcome to BITOG, have a seat over there fine sir!
But that is mostly what goes on.
I wish you the best of success in your endeavour to purge BITOG of this type of behavior. But a quick glance at many of the recent topics show that this type of thinking is alive and well. Have you visited the additive section lately? Holy cow poo Batman!!
And so what I am concluding from your rants and the various posturings of those in this thread is that the UOA's on this engine don't tell us about the presence or the lack thereof of the issue that Trav has observed first hand with them. And an even scarier extrapolation from that is that even if the lube appears to be healthy and fit for continued use, it may be allowing the build-up to occur. Of course that is a MAY situation, we have no proof for or against that statement. It seems we really don't have much quite frankly outside from a bunch of anecdotes and Trav's tear-down pictures of M1 0w-40 keeping one clean.
Does this mean that UOA's on this particular engine are essentially useless?
Ford acknowledged the issue and was fixing it under warranty. They were also blaming it on the plugs being changed incorrectly though, not sure if they still are. They also approved the Lock-n-stitch insert as a repair.
What they didn't do was honour fixes on the issue outside of warranty. But that doesn't mean they didn't acknowledge the presence of the issue.
Fixing it under warranty....pray tell....since when? There are quite a few forum sites that many owners, even with the extended warranty, that Ford said it was a spark plug problem and not a design issue and they denied warranty service. There only recommendation was total head replacements. Ford never acknowledged the helicoil as a fix. Ever. I for one would really like to see that information. A timesert is the only real solution to fixing the blow out, but after the blow out has happened. A lot of these engines were blowing plugs that were factory installed.
This is from a Honda tech on another forum regarding the 8th generation V6's:
Originally Posted By: ;1844129
do not listen to that bonehead regarding oil - you can use conventional oil. the manual does not state synthetic is required and whatever ANYONE else says doesn't matter. Honda will back the manual.
yes, you have a car that *can* be affected by piston ring issues. but these issues may not creep up because your driving style doesn't allow it to, such as short trips, heavy acceleration on a cold engine, driving in a manner that causes vcm to cycle rapidly...
an 8 year warranty on it is pretty generous on Hondas part to be honest. and I can't wait for it to expire because they are paying us [censored] money to replace piston rings on cylinders 1-2-3.
When they were replacing the heads under warranty........
Yes, that's correct, the warrantied fix was head replacement, they didn't do any "fixes" to the heads at the dealership for a vehicle under warranty other than that. I did hear of cases where Ford denied warranty saying it was somebody changing the plugs and stripping the threads, but for ones with factory plugs, or plugs changed AT the dealer, they were covered and got a new head or heads.
Luckily I didn't reference a helicoil then eh
No, the lock-n-stitch insert is the only "real way" to fix the heads, according to Ford at least, who approved the repair. I had #8 done on my truck, at the dealer, with this insert. Heli-coils back-out, some inserts use dissimilar metals that affect the heat transfer function of the plug to the head.
I've also posted this document on here before, so I'm quite surprised you didn't see it.
http://www.locknstitch.com/sparkpluginserts.htm
Quote:
Now approved by Ford Motor Company.
You can read further information on our Ford thread insert products here:
Ford Triton Instructions (350KB)
Ford Technical Service Bulletin (52KB)
Originally Posted By: Ford
ISSUE
Various 1997-2007 vehicles with a 5.4L 2V, or 6.8L 2V engine with stripped or missing spark plug port threads in modular engine aluminum heads. Ford Motor Company now authorizes LOCK-N-STITCH aluminum inserts and tool kit.
Seen nothing on the lock-n-stitch inserts. I know they would not allow helicoils...that's what they called them...in the early 01 and 02. Back then, and plently of other Ford brethren had this same problem early on, they only told the owners full head replacement, about that time, timesert came out. I remember there was a guy on the internet that would set up a date and time that would basically travel all over the US putting these in. He'd fly out to various cities and do a bunch, then fly to another city, etc. etc. That was around mid 2000's or so. There were so many complaints that Uncle Sam got involved and that's about where I dropped off from following. One thing I have summized is a lot of owners claim to hear a ticking sound prior to the plugs blowing out. I've been lucky with my truck, no blown plugs or tell tale ticking...but got to me honest, everytime I crank it up or drive on a long trip, I'm crossing my fingers. You say number 8 blew out....most have been number 4, furtherest back on passenger side and with Expedition, been some information that condensation drips right on top of that plug on that particular model by the way it was designed and that helped the plug start backing out.
Sounds like he wants customer pay time instead of warranty time...
In fairness it appears his post was in response to a dealer stating that:
Quote:
I have to use synthetic oil so that if a claim should manifest, I would be fully covered......ugh
The car in question is spec'ed for 0w-20. (is there a conventional 0w-20)?
http://www.driveaccord.net/forums/showthread.php?t=141065
So what I would find interesting if we could get past ford spark plugs, heli-coils and such is:
Do we think a UOA is going to ever pick the VCM issue up?
